Originally Posted by fireflimoon
Arxaw,
If I can't get one of those "older" versions of the 7777, I was thinking of the next alternative(s). The Wingard AP8780 (high amplication figures) and the CPA19 (because of the low noise figure) seemed possible.
Do you (or anyone else) have any thoughts or experience with these.
Thanks for your replies...
Arxaw,
You might be better off with the AP 8700 if your total coax run doesn't exceed 150'. You can also use RG11 for the main run of coax to cut down on the loss a little. You need to be careful with high gain preamps because they can get overloaded. Use just enough gain to do the job.
Chuck
