Update on the Audiovox DT60CFTR "RCA in-line F-connector for RG6 coax" splice kit
Since my previous posts:
http://www.avsforum.com/t/381623/the-official-avs-antenna-and-related-hardware-topic/14760#post_21974161
http://www.avsforum.com/t/381623/the-official-avs-antenna-and-related-hardware-topic/14790#post_21982470
I sent my broken and defective DT60CFTR splice kit to Audiovox, and a month later I received a new replacement DT60CFTR. Unfortunately, it is from the same bad lot with a Date Code of "3107SE". The DT60CFTR was sent back to Audiovox because the center connector diameter was too loose for reliable and tight contact with a standard RG6, .040" diameter center conductor. Testing with a bare Channel Master RG6 coax .039" dia. center conductor sample, I found the replacement DT60CFTR center contact is also too loose, at least on one side. The other side is sufficiently tight.
However, using a pair of mini needle nose pliers, I could squeeze the tiny DT60CFTR split-tube gold-plated center contact so that it does fit tight and reliably onto a .039" RG6 center conductor.
Hopefully, Audiovox engineers have heeded my complaint letter, sent with RG6 coax conductor samples and the defective DT60CFTR, so that DT60CFTRs sold in the future will not have this defect. In the meantime, you can still use this product only if you first test a bare sample of your RG6 coax center conductor for fit and adjust the DT60CFTR center contact with mini needle nose pliers for a tight fit before installing it.
Edited by Smoke_signal - 6/7/12 at 3:22am
