Originally Posted by
SubaruB4
Here is mine I forgot to change the antenna height but it's maybe 13 Ft which I doubt is going to make much of a difference.. In the morning I will check what my new setup will be I think it will be an extra 3-4 ft taller.
Hi,
I am wondering what the terrian is near you.
That color pattern (which is what I got using just your zipcode) makes me wonder if you are in a small valley with a hill or two between you and the transmittor.
On the original TVFool click on WNBC.
You will get a display of the hills and valleys between you and the transmittor.
But I am unedicated as to how to understand such an almost flat pattern, I am more used to lots more hills in the way. I am not even sure which end is which.
If you wish, send me a PM (Please do not post) with your Lat. and Lon. and I can use my mapping program to check closer.
At ~ 28 miles I am also puzzled by so many 1Edge entries.
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d99003ff02506fe
My main stations are ~ 36 miles and LOS. I just checked and the station at ~ 97 miles is just fine right now.
I hope someone more knowledagable will help explain and help more.
I find the Google earth TVFool page to be more understandable, but then I do a lot of mapping.
SHF
