Originally Posted by
beastyben1
But! I snapped some pictures of the antenna setup from the previous owner of the house. All I could find coming into the attic is that flat brown cable. Shouldn't I be able to use this? It's freakin massive. Snow is almost gone so I can get up in a few weeks hopefully.
Hi,
Something does not compute!
My memory of 300 ohm flat cable is from ~ 1960, the dressing of the cable in the lowest antenna picture looks much more like coax than than flat 300 ohm cable.
And to my eyes there are two round cables coming down from the top antennas at least as far as the lower antenna.
Go outside and try and determine where the cable from the massive antenna enters the attic.
You have not said if you or the previous owner had cable, fiber optic or coax.
What do you find where the TV set(s) may have been located.
I can accept that a cable installer upon seeing the massive antenna wanting to insure it never was used again and cut the cable(s) to it.
I cut the mickey mouse dual cable TV flush with the wall when I left. (That cable is still in use as well as what was preinstalled in my new {~1974} house.) All my attic antenna cables were / are coax.
The antenna cable may also have been cut to stop any water getting inside the house.
That antenna system is just too good to have been connected (badly) with a single 300 ohm flat line.
SHF
