Thanks for the compliment, Tyler.Originally Posted by tylerSC
Very nice set up there Larry. Do you use a preamp with any of those antennas or just a dist amp? And have you tried the new version 4228? I prefer their original versions before they subcontracted Chinese made imitations. I still use their 4248 UHF Diamond antenna which is a very good performer, but it is no longer available. I guess 91XG is the best choice now for that type of antenna.
I've tried several pre-amps here, but none of them can handle the signals I get from Sutro Tower, just 3/4 of a mile away. TVFool shows the Noise Margin from the 11 stations up there to be from 89 to 78 dB. I have about 70 feet of coax on the antennas, so a preamp would probably help for the distant stations, but no such luck. The distribution amp gives me a +1 dB gain over the input from the antennas, but I could use a few dB more!
I haven't tried the new version of the 4228. From what I've heard it's not as good as these originals that I'm using.
Larry
SF
