Well, as luck would have it, guess what came in the mail today? An updated version of the "Design Guidelines and Review Procedures for Residential Modifications," i.e., HOA restrictions.
Under the heading, "Disallowed Items at ..."
Shall include but not be limited to the following:
Exterior antenna of any kind with the exception of miniature satellite dishes as detailed in these Guidelines.
Now, before we jump the gun, and everyone posts this link (unless this is outdated):
http://www.fcc.gov/mb/facts/otard.html
There are some questions to answer.
First, what exactly does this mean?
Q: What types of antennas are covered by the rule?
A: The rule applies to the following types of antennas:
(1) A "dish" antenna that is one meter (39.37") or less in diameter (or any size dish if located in Alaska) and is designed to receive direct broadcast satellite service, including direct-to-home satellite service, or to receive or transmit fixed wireless signals via satellite.
(2) An antenna that is one meter or less in diameter or diagonal measurement and is designed to receive video programming services via broadband radio service (wireless cable) or to receive or transmit fixed wireless signals other than via satellite.
(3) An antenna that is designed to receive local television broadcast signals. Masts higher than 12 feet above the roofline may be subject to local permitting requirements.
In addition, antennas covered by the rule may be mounted on "masts" to reach the height needed to receive or transmit an acceptable quality signal (e.g. maintain line-of-sight contact with the transmitter or view the satellite). Masts higher than 12 feet above the roofline may be subject to local permitting requirements for safety purposes. Further, masts that extend beyond an exclusive use area may not be covered by this rule.
I'm guessing that #2 is not the one that applies, but #3 (I hope)?
Because, at this point, my HD7084P is much larger than 1 meter in diameter, 131" to be exact.
Please help me understand this, before mounting the tripod. At this point, I'm stopping work. Also, if I do go ahead with this, because the FCC says that HOA cannot impose these restrictions, do I have a long battle ahead of me, or get in danger of being on the blacklist or something?
