Originally Posted by afiggatt
First, all of the stations on your list are currently digitally broadcasting on UHF channels (the actual broadcast channel is the last number on the row). All, except for the CW station, are only 14 miles away and in the same exact direction. WRLH-DT Fox 35 comes in with a red color code, but the FCC data base shows a STA low power of 12.4 KW and a full power construction permit. Check with the Richmond locals thread to find out if WRLH-DT has gone full power or not.
If the CW station is not that important, you should be able to get the locals with an indoor Silver Sensor UHF antenna. Circuit City has been selling them under the Philips band name for $25, model # PHDTV1. If you have an attic, you could consider putting up a Channel Master 4221 4 Bay bowtie UHF antenna. It should get all your stations including the CW station.
Awesome. I really appreciate the advice.
