AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › WiRNS 1.1.x Beta
WiRNS 1.1.x Beta
post #1 of 275
WiRNS has attained beta status
WARNING: CERTAIN FUNCTIONS ARE ONLY AVAILABLE ON http://wirnsip/ RATHER THAN THAT 127.0.0.1 INTERFACE.
WARNING: CERTAIN FIREWALLS ARE KNOWN TO CAUSE PROBLEMS, IF YOU HAVE ONE AND HAVE A PROBLEM TRY TURNING IT OFF FIRST.
CHANGELOG:
1.1.2:
- Multi-replay bugfixes
- Todo bugfixes for people with theme channels
1.1.1:
- Major bugfix release.
1.1.0b:
- Rearchitected menu
- Massive revamp of the database
- Massive revamp of the todo subsystem
- Major revamp of the guide subsystem.
- All lingering ".conf" files moved back into the db.
- DVA3 Listings support
DONATION INFO:
WiRNS is free software, but due to user demand I'm now accepting donations. Every dollar donated to this project will go towards furthering WiRNS (buying me a Replay 5500, 4xxx, or more replays to come up with more ideas in the future), _OR_ be donated to a Cancer charity of my choice.
PLEASE READ THE TERMS & CONDITIONS ON SOURCEFORGE DONATION SYSTEM FIRST. THEY DO TAKE A SMALL CUT TO MAINTAIN THEIR SITE AND HAVE SOME CONDITIONS ON REFUNDS AND THE LIKE.
CLICK HERE TO DONATE
FEATURES:
- Web based scheduling for 4000/5000 users
- Alternative guide delivery (canadians, other non-americans)
- Web based channel guide
- Tivo style ToDo list
- Show searching (better than replays)
- PPV Support for DISH Network users.
REQUIREMENTS:
- .NET Framework v1.1
UPGRADING:
- Dont, major changes, reinstall its easier.
INSTALLATION:
- Get the archive and unzip it to a folder
- Get an account on http://labs.zap2it.com/ Use this certificate code: DQYN-JQ2N-IBUT
- Setup your zap2it labs account (add all your lineups)
- Double click the StartWirns.bat file
- Open a web browser and go to http://127.0.0.1:8923/
- Click Configuration->WiRNS
WiRNS IP: The ip address that wirns will bind to port 80 on your pc.
DNS Server: A dns server that is accessible from your PC (usually your ISPs)
- Click Configuration->DataDirect
Username: The username you signed up to DD with.
Password: The password you signed up to DD with.
- Click Administration->Update Guide
- Watch the Server window, it will eventually say:
"Processing ToDo Information"
- Close the server
- Double Click StartWirns.bat again
- Click Configuration->Replays
- Add all your replays
- Click Administration->Update Guide again to rebuild the ToDo lists
- Wait for the update to finish, and restart the server again.
- Reconfigure your replay to use a static ip, make the DNS1 and DNS2 your wirnsip
- Change the zipcode on your replay to proxy through wirns
- Enjoy.
The installation instructions are a little convoluted involving far to many restarts, I apologize and will clean it up in coming releases.
-kjac
wirns-1.1.2b.zip 275.7890625k . file
post #2 of 275
Just installed this.
You are the man Kjac....
CP
post #3 of 275
Also, some of the menu functions dont do stuff yet; those plugins aren't done (ie; ReplayGuide; this will eventually be a replica of the ReplayGuide on your replay)
-kjac
post #4 of 275
Ok not sure if I did something wrong or not. Trying to access the Guide server I get the following error:
[2004-03-26 18:16:07] WiRNS v1.1.0 build 36197 - (c) 2004 kjac
[2004-03-26 18:16:07] Thanks: ijprest, waynethedvrguy, Remmer99, gduprey, LeeTho
mpson, j.m., archdog99, FlipFlop and all the other Replay Hackers out there.
[2004-03-26 18:16:07] Initializing.
[2004-03-26 18:16:07] Cleaning up database.
[2004-03-26 18:16:07] Vacuuming database
[2004-03-26 18:16:35] Detected that I'm running from command line.
[2004-03-26 18:16:35] Loading configuration
[2004-03-26 18:16:35] Starting guide update timer.
[2004-03-26 18:16:35] Detected configuration settings. Starting Replay Emulatio
n server on: 192.168.1.10
[2004-03-26 18:16:35] Loading server plugins.
[2004-03-26 18:16:36] Loading ReplayZone genre data.
[2004-03-26 18:16:44] Plugin: ChannelGuideProvider.dll (1.0.1546.35321) loaded.
[2004-03-26 18:16:44] Refreshing RecordingGuide for: Living Room(192.168.1.11)
[2004-03-26 18:16:49] Parsed 12/12 entries.
[2004-03-26 18:16:49] Plugin: GuideServer.dll (1.0.1546.35320) loaded.
[2004-03-26 18:16:49] Plugin: HeadendProvider.dll (1.0.1546.35319) loaded.
[2004-03-26 18:16:49] Plugin: PutSyslogProvider.dll (1.0.1546.35318) loaded.
[2004-03-26 18:16:49] Plugin: ServerManagment.dll (1.0.1546.35317) loaded.
[2004-03-26 18:16:49] Plugin: XactProvider.dll (1.0.1546.35315) loaded.
[2004-03-26 18:16:49] Plugin: ZipcodeProvider.dll (1.0.1546.35316) loaded.
[2004-03-26 18:16:49] Replay Network Server Emulation started.
[2004-03-26 18:16:49] Starting configuration server on 127.0.0.1:8923
[2004-03-26 18:16:49] Loading server plugins.
[2004-03-26 18:16:49] Starting ntp proxy server.
[2004-03-26 18:16:49] Starting DNS Proxy
[DNS] micro_dns initializing
[DNS] Attempting to reply with 192.168.1.10 for production queries.
[DNS] Attempting to proxy non-production requests to 192.168.1.1.
[DNS] micro_dns listing on port 53
[INFO] Exception caught in handler: An existing connection was forcibly closed b
y the remote host
at System.Net.Sockets.Socket.BeginSend(Byte[] buffer, Int32 offset, Int32 siz
e, SocketFlags socketFlags, AsyncCallback callback, Object state)
at WiRNS.Server.ReplayNetworkServer.HandleMessage(String message, Byte[] requ
estContent, Socket handler)
at WiRNS.Server.ReplayNetworkServer.ReadCallBack(IAsyncResult l_AsyncRes)
Any ideas?
post #5 of 275
Great job kjac,
works great with DVA TV listings,
Howie
post #6 of 275
Your browser timed out or closed the connection or something. Restart and try again. Make sure you have your replay(s) configured or the guide server behaves wonky.
EDIT: I may have also introduced a bug with " "'s in replay names again. Thats the only thing I forgot to check. If you restart and it still doesn't work, delete your replay and recreate it without a space. Trigger guide update. Restart, and see if it still happens. Let me know the outcome of these steps.
EDIT2: I tested names with " "s locally. They worked fine. Try a restart, please feedback.
Off to watch a movie with the g/f. Be back in ~2hrs.
-kjac
post #7 of 275
duckman, do a netstat -an from the command line before starting wirns, and see what you have listening. your error looks like an existing service sitting on one of those ports...
post #8 of 275
Originally posted by rkramer
i started it once, and then realized i wanted to bind it to another IP. shut down, restart, and now I get the following error from windows when I start up wirns.
"windows service start failure, cannot start service... "
Delete the WiRNS.db file, it will recreate it and let you restart config from scratch.
The error you got was from double clicking WiRNS, instead of the .bat file.
-kjac
post #9 of 275
one of those days! I've been staring at c# .net code all day working out an ugly problem, after that I sometimes revert back to wannabe AOL user... :D
anyway, after my mind kicked in I just extracted the archive and was up and running...
post #10 of 275
duckman,
Were you able to consistently replicate the problem?
-kjac
post #11 of 275
kjac,
This is a wonderful update to a great utility. I really do appreciate your hard work.
In the interest of making it as bulletproof as possible I respectfully submit the following.
I seem to be able to generate the same error as duckman at will by selecting Administration->Update Replay and then, a few seconds later, selecting Tools-> Channel Guide. The operation does not seem to be affected.
WiRNS window:
F:\\WiRNS>WiRNS.exe -server
[2004-03-27 10:48:20] WiRNS v1.1.0 build 36197 - (c) 2004 kjac
[2004-03-27 10:48:20] Thanks: ijprest, waynethedvrguy, Remmer99, gduprey, LeeThompson, j.m., archdog99, FlipFlop and all the other Replay Hackers out there.
[2004-03-27 10:48:20] Initializing.
[2004-03-27 10:48:20] Cleaning up database.
[2004-03-27 10:48:20] Vacuuming database
[2004-03-27 10:48:31] Detected that I'm running from command line.
[2004-03-27 10:48:31] Loading configuration
[2004-03-27 10:48:31] Starting guide update timer.
[2004-03-27 10:48:31] Detected configuration settings. Starting Replay Emulation server on: 192.168.2.97
[2004-03-27 10:48:31] Loading server plugins.
[2004-03-27 10:48:31] Loading ReplayZone genre data.
[2004-03-27 10:48:34] Plugin: ChannelGuideProvider.dll (1.0.1546.35321) loaded.
[2004-03-27 10:48:34] Refreshing RecordingGuide for: RTV(192.168.2.90)
[2004-03-27 10:48:53] Parsed 71/71 entries.
[2004-03-27 10:48:53] Plugin: GuideServer.dll (1.0.1546.35320) loaded.
[2004-03-27 10:48:53] Plugin: HeadendProvider.dll (1.0.1546.35319) loaded.
[2004-03-27 10:48:53] Plugin: PutSyslogProvider.dll (1.0.1546.35318) loaded.
[2004-03-27 10:48:53] Plugin: ServerManagment.dll (1.0.1546.35317) loaded.
[2004-03-27 10:48:53] Plugin: XactProvider.dll (1.0.1546.35315) loaded.
[2004-03-27 10:48:53] Plugin: ZipcodeProvider.dll (1.0.1546.35316) loaded.
[2004-03-27 10:48:53] Replay Network Server Emulation started.
[2004-03-27 10:48:53] Starting configuration server on 127.0.0.1:8923
[2004-03-27 10:48:53] Loading server plugins.
[2004-03-27 10:48:53] Starting ntp proxy server.
[2004-03-27 10:48:53] Starting DNS Proxy
[DNS] Attempting to reply with 192.168.2.97 for production queries.
[DNS] Attempting to proxy non-production requests to 192.168.2.1.
[2004-03-27 22:48:53] Updating ReplayGuide information
[2004-03-27 22:48:54] Refreshing RecordingGuide for: RTV(192.168.2.90)
[2004-03-27 22:49:14] Parsed 71/71 entries.
[2004-03-27 23:40:16] Updating ReplayGuide information
[2004-03-27 23:40:16] Refreshing RecordingGuide for: RTV(192.168.2.90)
[2004-03-27 23:40:20] Updating ReplayGuide information
[2004-03-27 23:40:20] Refreshing RecordingGuide for: RTV(192.168.2.90)
[2004-03-27 23:40:35] Parsed 73/73 entries.
[INFO] Exception caught in handler: An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.BeginSend(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, AsyncCallback callback, Object state) at WiRNS.Server.ReplayNetworkServer.HandleMessage(String message, Byte[] requestContent, Socket handler) at WiRNS.Server.ReplayNetworkServer.ReadCallBack(IAsyncResult l_AsyncRes)
[2004-03-27 23:40:40] Parsed 73/73 entries.
[2004-03-27 23:42:17] Updating ReplayGuide information
[2004-03-27 23:42:17] Refreshing RecordingGuide for: RTV(192.168.2.90)
[2004-03-27 23:42:37] Parsed 73/73 entries.
[2004-03-27 23:46:25] Updating ReplayGuide information
[2004-03-27 23:46:25] Refreshing RecordingGuide for: RTV(192.168.2.90)
[2004-03-27 23:46:44] Parsed 73/73 entries.
Also, I am getting a IE error on some pages. The error popup is shown in the attached file.
Once again, thanks so much!
ltj
post #12 of 275
Hmmm. Missed the attachment...
post #13 of 275
ltj,
The float error is antiquated code that isn't run anymore. I'll clean it up in 1.1.1, if you restart can you still not get the ChannelGuide??? What are the specs of your pc? Send me your WiRNS.db so I can see whats going on if you can..
-kjac
post #14 of 275
ltj,
I just reread your post, and I think I understand now... you're saying if you update the guide from your replay then "immediately" click the channel guide you get that error; does the channel guide still render in that case or no?
-kjac
post #15 of 275
I'm trying to setup BEV. I don't understand this step...
Where/how do I input this data?
Also, can the Replay change channels on the IRD? How do I make that happen?
Also, getting this error:
Unhandled Exception: System.NullReferenceException: Object reference not set to
an instance of an object.
at WiRNS.WiRNSService.StartMicroDns()
[2004-03-28 05:39:06] Guide update manually initiated.
[2004-03-28 05:39:06] Purging old guide information
[2004-03-28 05:39:10] Updating guide information in the database.
[2004-03-28 05:39:10] Processing guide information for: Sun Mar 28
[2004-03-28 05:39:45] Processing guide information for: Mon Mar 29
[2004-03-28 05:40:21] Processing guide information for: Tue Mar 30
[2004-03-28 05:40:59] Processing guide information for: Wed Mar 31
[2004-03-28 05:41:39] Processing guide information for: Thu Apr 01
[2004-03-28 05:42:18] Processing guide information for: Fri Apr 02
[2004-03-28 05:42:58] Processing guide information for: Sat Apr 03
[2004-03-28 05:43:41] Processing guide information for: Sun Apr 04
[2004-03-28 05:44:22] Processing guide information for: Mon Apr 05
[2004-03-28 05:45:07] Processing guide information for: Tue Apr 06
[2004-03-28 05:45:53] Processing guide information for: Wed Apr 07
[2004-03-28 05:46:41] Processing guide information for: Thu Apr 08
[2004-03-28 05:47:29] Processing guide information for: Fri Apr 09
[2004-03-28 05:47:57] Processing guide information for: Sat Apr 10
[2004-03-28 05:48:01] Parsing PPV Configurations.
[2004-03-28 05:48:01] Processing ToDo Information.
[2004-03-28 05:48:01] Refreshing RecordingGuide for: Replay(192.168.0.103)
[2004-03-28 05:48:06] Parsed 70/70 entries.
[2004-03-28 05:48:06] Building ToDo List for: Replay
[2004-03-28 05:48:10] WiRNSService.BuildToDo(): System.IndexOutOfRangeException:
Index was outside the bounds of the array.
at WiRNS.WiRNSService.BuildToDo()
Unhandled Exception: System.IndexOutOfRangeException: Index was outside the boun
ds of the array.
at WiRNS.WiRNSService.DoGuideUpdate()
post #16 of 275
kjac,
EDIT: Not updating from my Replay, from http://192.168.2.97/manage/ReplayGuideUpdate.
And yes, the guide renders then the error is generated.
ltj
post #17 of 275
I'm getting down to the scraping of info for PPV, and getting the following error:
[2004-03-28 05:07:05] Parsing PPV Configurations.
[2004-03-28 05:07:05] Fetching DishNetwork PPV
[2004-03-28 05:08:16] WiRNSService.DoDishPPV(): System.Exception: Exception occured while fetching Dish PPV Listings. ---> System.Net.WebException: The underlying connection was closed: Unable to connect to the remote server.
at System.Net.HttpWebRequest.CheckFinalStatus()
at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult)
at System.Net.HttpWebRequest.GetRequestStream()
at WiRNS.PPV.DishNetwork.DishParser.SendRequest(Uri destination, String requestMethod, Byte[] requestBytes)
--- End of inner exception stack trace ---
at WiRNS.PPV.DishNetwork.DishParser.FetchTMSID(String date, String tmsid)
at WiRNS.PPV.DishNetwork.DishParser.FetchListings()
at WiRNS.WiRNSService.DoDishPPV(String providerName, String timezone)
[2004-03-28 05:08:16] WiRNSService.DoPPV(): System.Exception: Exception occured while fetching Dish PPV Listings. ---> System.Net.WebException: The underlying connection was closed: Unable to connect to the remote server.
at WiRNS.WiRNSService.DoPPV()
My schedule is from the DISH national feed. I entered the text as "DISH Network". Is this the right text to be using?
What is the IP of the source of PPV listings, so I can check if I can open it in a regular browser?
post #18 of 275
Ok,
I think I've found 1 problem that I'll work on today that is causing "double clicks" and sending messages twice. The PPV site was down last night, it should be back now.
EDIT: What browser is everyone using?
Guerito,
You seem to have some serious configuration problems with your replay(s) and wirnsip. Double check all those settings.
-kjac
post #19 of 275
I use mozilla or maybe safari.
post #20 of 275
[2004-03-28 11:41:05] Starting DNS Proxy
[DNS] Attempting to reply with 192.168.0.105 for production queries.
[DNS] Attempting to proxy non-production requests to 192.195.240.1.
EX: Index was out of range. Must be non-negative and less than the size of the
collection.
Parameter name: index
at System.Collections.SortedList.GetKey(Int32 index)
at WiRNS.GuideServerPlugin.DoServeGuide(String requestValues)
at WiRNS.GuideServerPlugin.HandleMessage(String message, Byte[] data)
collection.
this occurs every time I select view guide. An empty web page results.
Mozilla 1.7 latest nightly build.
E
post #21 of 275
collection.
collection.
E
Try the new build, make sure you have a replay configured.
-kjac
post #22 of 275
I am having a problem connecting Replay to WiRNS Server:
WiRNS Log:
[2004-03-28 14:59:05] Detected configuration settings. Starting Replay Emulation server on: 192.168.1.2
[2004-03-28 14:59:05] Loading server plugins.
[2004-03-28 14:59:19] Replay Network Server Emulation started.
[2004-03-28 14:59:19] Starting ntp proxy server.
[2004-03-28 14:59:19] Starting DNS Proxy
[DNS] Attempting to reply with 192.168.1.2 for production queries.
[DNS] Spoofing response of 57 bytes
[DNS] Spoofing response of 59 bytes
[DNS] Spoofing response of 64 bytes
ReplayTV Error Message:
"Your ReplayTV got an invalid response from your name server"
ReplayTV Settings:
IP Address 192.168.1.10
Subnet Mask: 255.255.255.0
Gateway: 192.168.1.1 <-- My Router
DNS Server 1: 192.168.1.2 <-- My computer where WiRNS Server is running
DNS Server 2: 192.168.1.2
WiRNS Settings:
WiRNS IP: 192.168.1.2 <-- My computer where WiRNS Server is running
DNS Server IP: 192.168.1.1 <-- My Router
Any ideas?
post #23 of 275
WiRNS Log:
ReplayTV Settings:
WiRNS Settings:
Any ideas?
Get ethereal and do a packet dump of the communcation to send me. It looks like microdns is responding with a value that the replay cant connect to.
-kjac
post #24 of 275
Kjac -
Since this build does not let me look at/modify existing RTV settings, I'm not CERTAIN that they're correct... But I did as you suggested with the new build. I deleted both of them, reprogrammed them, restarted wirns, updated the guide... and still nothing.
Well, nothing but this error:
Code:
2004-03-28 15:27:35] GuideServer.DoToDo(): Exception: System.InvalidOperationEx
eption: Operation is not valid due to the current state of the object.
  at Finisar.SQLite.SQLiteCommand.set_CommandText(String commandText)
  at WiRNS.GuideServerPlugin.DoToDo(Int32 offset, Int32 days)
X: Operation is not valid due to the current state of the object.
EDIT - Hmmm... one more restart and now I have GUIDE!
John
post #25 of 275
Please see attached...
replay.zip 1.8486328125k . file
post #26 of 275
Originally posted by Bigjohns
Kjac -
Code:
John
Looks like I'm not closing a reader properly. I'll try to track it down.
EDIT: What were you doing right before you clicked on the ToDo?
-kjac
post #27 of 275
It appears that the WiRNS Server isn't listening on port 80 on your wirnsip. Make sure that nothing else is bound to that port (IIS, DVA, etc) that is preventing it from starting up. Restart it and make sure it starts cleanly.
-kjac
post #28 of 275
Guerito,
-kjac
Can you give me a hint? I've checked the settings several times now. I'm not a network guy, so it may not be correct. Is there a FAQ somewhere? I haven't been able to find one. For example, what do I use for Input 1? There is no BEV option. Also, what zip code do I use, since it won't allow me to use letters?
post #29 of 275
Guerito,
Did you follow the installation instructions? You need a datadirect account and to get that info into WiRNS before you start dealing with the Replay itself.
-kjac
post #30 of 275
Kjac -
I can open guide, but not TODO.
John
Code:
[2004-03-28 16:42:43] GuideServer.DoToDo(): Exception: System.InvalidOperationEx
ception: Operation is not valid due to the current state of the object.
EX: Operation is not valid due to the current state of the object.
[2004-03-28 16:42:49] GuideServer.DoToDo(): Exception: System.InvalidOperationEx
  Back to Forum: ReplayTV & Showstopper PVRs
This thread is locked
