AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › WiRNS 1.1.x Beta
WiRNS 1.1.x Beta - Page 2
post #31 of 275
Kjac,
Yes I have replicated it. Apparently it is only happening when I try to view the ToDo list...
[INFO] Exception caught in handler: An existing connection was forcibly closed by the remote hostat System.Net.Sockets.Socket.BeginSend(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags, AsyncCallback callback, Object state) at WiRNS.Server.ReplayNetworkServer.HandleMessage(String message, Byte[] requestContent, Socket handler) at WiRNS.Server.ReplayNetworkServer.ReadCallBack(IAsyncResult l_AsyncRes)
EDIT: Sorry didn't realize you released a new release I will edit this after testing it on the new release.
Also as far as Directv PPV info maybe the attatched perl script I found can help you code something to parse it.
CP
getppv.pl.txt 22.3017578125k . file
post #32 of 275
Originally posted by Bigjohns
Kjac -
I can open guide, but not TODO.
John
Code:
[2004-03-28 16:42:43] GuideServer.DoToDo(): Exception: System.InvalidOperationEx
ception: Operation is not valid due to the current state of the object.
   at Finisar.SQLite.SQLiteCommand.set_CommandText(String commandText)
   at WiRNS.GuideServerPlugin.DoToDo(Int32 offset, Int32 days)
EX: Operation is not valid due to the current state of the object.
   at WiRNS.GuideServerPlugin.HandleMessage(String message, Byte[] data)
[2004-03-28 16:42:49] GuideServer.DoToDo(): Exception: System.InvalidOperationEx
john,
If you restart and go straight to ToDo does it work?
EDIT: Also have you upgraded to 1.1.1?
EDIT2: I can't replicate this here, it seems you have a lock stuck on the database somewhere. Try recreating it all from scratch with 1.1.1 if nothing else works.
-kjac
post #33 of 275
I'm using:
Code:
[2004-03-28 15:30:54] WiRNS v1.1.1 build 26305 - (c) 2004 kjac
And no, todo does not appear after restart either...
Code:
E:\\wirns>WiRNS.exe -server
[2004-03-28 17:50:44] WiRNS v1.1.1 build 26305 - (c) 2004 kjac
[2004-03-28 17:50:44] Thanks: ijprest, waynethedvrguy, Remmer99, gduprey, LeeTho
mpson, j.m., archdog99, FlipFlop and all the other Replay Hackers out there.
[2004-03-28 17:50:44] Initializing.
[2004-03-28 17:50:44] Cleaning up database.
[2004-03-28 17:50:45] Vacuuming database
[2004-03-28 17:52:36] Detected that I'm running from command line.
[2004-03-28 17:52:36] Loading configuration
[2004-03-28 17:52:36] Starting guide update timer.
[2004-03-28 17:52:36] Detected configuration settings.  Starting Replay Emulatio
n server on: 192.168.0.100
[2004-03-28 17:52:36] Loading server plugins.
[2004-03-28 17:52:37] Loading ReplayZone genre data.
[2004-03-28 17:52:42] Plugin: ChannelGuideProvider.dll (1.0.1546.35939) loaded.
[2004-03-28 17:52:42] Refreshing RecordingGuide for: FamilyRoom(192.168.0.51)
[2004-03-28 17:52:53] Parsed 55/55 entries.
[2004-03-28 17:52:53] Refreshing RecordingGuide for: BedRoom(192.168.0.41)
[2004-03-28 17:53:04] Parsed 36/36 entries.
[2004-03-28 17:53:04] Plugin: GuideServer.dll (1.0.1548.26084) loaded.
[2004-03-28 17:53:04] Plugin: HeadendProvider.dll (1.0.1546.35319) loaded.
[2004-03-28 17:53:04] Plugin: PutSyslogProvider.dll (1.0.1546.35318) loaded.
[2004-03-28 17:53:04] Plugin: ServerManagment.dll (1.0.1548.25234) loaded.
[2004-03-28 17:53:04] Plugin: XactProvider.dll (1.0.1546.35315) loaded.
[2004-03-28 17:53:04] Plugin: ZipcodeProvider.dll (1.0.1546.35316) loaded.
[2004-03-28 17:53:04] Replay Network Server Emulation started.
[2004-03-28 17:53:04] Starting configuration server on 127.0.0.1:8923
[2004-03-28 17:53:04] Loading server plugins.
[2004-03-28 17:53:04] Starting ntp proxy server.
[2004-03-28 17:53:04] Starting DNS Proxy
[DNS] micro_dns initializing
[DNS] Attempting to reply with 192.168.0.100 for production queries.
[DNS] Attempting to proxy non-production requests to 192.168.0.1.
[DNS] micro_dns listing on port 53
[2004-03-28 17:54:27] GuideServer.DoToDo(): Exception: System.InvalidOperationEx
post #34 of 275
I'm using:
Code:
Code:
John,
Try deleteing 1 replay, restarting and let me know if it still happens..
-kjac
post #35 of 275
Seems to be fixed in the newest version.
Will that perl script be able to help with Directv PPV listings?
One more question, has sourceforge fixed the cvs yet?
CP
post #36 of 275
CP
duck,
That PPV script (from the tivo guys) wont work, as TVGuide doesn't have PPV info for DTV anymore (I dont think). Sourceforge probably wont act upon the ticket until monday at the earliest. Its a public ticket in their tracking system, so you can all watch it.
-kjac
post #37 of 275
Bigj,
It is a multi-replay bug. I managed to replicate it and am working it out now.
-kjac
post #38 of 275
post #39 of 275
Originally posted by kjac
Guerito,
Did you follow the installation instructions? You need a datadirect account and to get that info into WiRNS before you start dealing with the Replay itself.
-kjac
Maybe I don't know what a datadirect account is then. In my previous post, it shows:
[2004-03-28 05:39:10] Updating guide information in the database.
[2004-03-28 05:39:10] Processing guide information for: Sun Mar 28
[2004-03-28 05:39:45] Processing guide information for: Mon Mar 29
[2004-03-28 05:40:21] Processing guide information for: Tue Mar 30
[2004-03-28 05:40:59] Processing guide information for: Wed Mar 31
[2004-03-28 05:41:39] Processing guide information for: Thu Apr 01
[2004-03-28 05:42:18] Processing guide information for: Fri Apr 02
[2004-03-28 05:42:58] Processing guide information for: Sat Apr 03
[2004-03-28 05:43:41] Processing guide information for: Sun Apr 04
[2004-03-28 05:44:22] Processing guide information for: Mon Apr 05
[2004-03-28 05:45:07] Processing guide information for: Tue Apr 06
[2004-03-28 05:45:53] Processing guide information for: Wed Apr 07
[2004-03-28 05:46:41] Processing guide information for: Thu Apr 08
[2004-03-28 05:47:29] Processing guide information for: Fri Apr 09
[2004-03-28 05:47:57] Processing guide information for: Sat Apr 10
I thought that was the account information the Replay needs. I'l ask again, is there a FAQ somewhere? So far not one of my questions has been answered. I've read what I could find, but don't know what to enter for the inputs and zipcode.
post #40 of 275
Guerito,
Why dont you start by telling me what you're trying to do and where you're getting stuck? It sounds like you're trying to get BEV on your replay; if thats the case, you add BEV to your datadirect account, and update the wirns guide as you did. When that process is completed; go to your replay and go into network and input settings; change your ethernet connection settings to manual. Give the replay a free ip in your subnet, give it the same netmask as your PC, and the same router as your PC. Set DNS1 and DNS2 to the ipaddress of your pc running wirns. When that is done, change the zipcode on the replay to any other zipcode in your timezone. It will force you to reset your inputs, and then you pick the provider(s) for the input(s) that you want from the list. WiRNS will return all the real providers for that zipcode, along with the ones you configured in DataDirect.
-kjac
post #41 of 275
Originally posted by CCCP
I am having a problem connecting Replay to WiRNS Server:
ReplayTV Error Message:
"Your ReplayTV got an invalid response from your name server"
Any ideas?
I have noticed that the replaytv initial setup some times will give this error if the DNS lookup returns a 192.168.x.x address. When this happened to me, I set the DNS server to a normal server on initial setup, and then once things were operating, when into the change network settings and changed the DNS back to the spoofing one.
So try this: use the 192.168.1.1 (your router) as the DNS on the replaytv, and get the network set up. Then go back and change the DNS back to 192.168.1.2 (your WiRNS machine).
post #42 of 275
kjac,
I am was having the same problem that bigj was. i have the new guideserver.dll that you posted and now have the following problem:
on another system go to wirnsip and request the todo list and get the 2 replays listed and nothing under either. when i request the channel guide i get the guide and have the markings for the systems in the guide. below is the log from wirnsstarting with the guide update and then a reestart after adding the second replay:
[2004-03-28 21:30:15] Updating guide information in the database.
[2004-03-28 21:30:15] Processing guide information for: Sun Mar 28
[2004-03-28 21:30:32] Processing guide information for: Mon Mar 29
[2004-03-28 21:30:47] Processing guide information for: Tue Mar 30
[2004-03-28 21:31:02] Processing guide information for: Wed Mar 31
[2004-03-28 21:31:17] Processing guide information for: Thu Apr 01
[2004-03-28 21:31:32] Processing guide information for: Fri Apr 02
[2004-03-28 21:31:50] Processing guide information for: Sat Apr 03
[2004-03-28 21:32:09] Processing guide information for: Sun Apr 04
[2004-03-28 21:32:24] Processing guide information for: Mon Apr 05
[2004-03-28 21:32:40] Processing guide information for: Tue Apr 06
[2004-03-28 21:32:56] Processing guide information for: Wed Apr 07
[2004-03-28 21:33:12] Processing guide information for: Thu Apr 08
[2004-03-28 21:33:35] Processing guide information for: Fri Apr 09
[2004-03-28 21:33:53] Processing guide information for: Sat Apr 10
[2004-03-28 21:33:55] Parsing PPV Configurations.
[2004-03-28 21:33:55] Processing ToDo Information.
[2004-03-28 21:33:55] Refreshing RecordingGuide for: wrlwnd2(192.168.1.110)
[2004-03-28 21:33:56] Parsed 14/16 entries.
[2004-03-28 21:33:56] Refreshing RecordingGuide for: wrlwnd(192.168.1.120)
[2004-03-28 21:33:57] Parsed 39/40 entries.
[2004-03-28 21:33:57] Building ToDo List for: wrlwnd
[2004-03-28 21:34:00] WiRNSService.BuildToDo(): System.IndexOutOfRangeException: Index was outside the bounds of the array.
at WiRNS.WiRNSService.BuildToDo()
[2004-03-28 21:35:11] WiRNS v1.1.1 build 26305 - (c) 2004 kjac
[2004-03-28 21:35:11] Thanks: ijprest, waynethedvrguy, Remmer99, gduprey, LeeThompson, j.m., archdog99, FlipFlop and all the other Replay Hackers out there.
[2004-03-28 21:35:11] Initializing.
[2004-03-28 21:35:11] Cleaning up database.
[2004-03-28 21:35:11] Vacuuming database
[2004-03-28 21:35:43] Detected that I'm running from command line.
[2004-03-28 21:35:43] Loading configuration
[2004-03-28 21:35:43] Starting guide update timer.
[2004-03-28 21:35:43] Detected configuration settings. Starting Replay Emulation server on: 192.168.1.130
[2004-03-28 21:35:43] Loading server plugins.
[2004-03-28 21:35:43] Loading ReplayZone genre data.
[2004-03-28 21:35:52] Plugin: ChannelGuideProvider.dll (1.0.1546.35939) loaded.
[2004-03-28 21:35:52] Refreshing RecordingGuide for: wrlwnd2(192.168.1.110)
[2004-03-28 21:35:53] Parsed 14/16 entries.
[2004-03-28 21:35:53] Refreshing RecordingGuide for: wrlwnd(192.168.1.120)
[2004-03-28 21:35:54] Parsed 39/40 entries.
[2004-03-28 21:35:54] Plugin: GuideServer.dll (1.0.1548.33671) loaded.
[2004-03-28 21:35:55] Plugin: HeadendProvider.dll (1.0.1546.35319) loaded.
[2004-03-28 21:35:55] Plugin: PutSyslogProvider.dll (1.0.1546.35318) loaded.
[2004-03-28 21:35:55] Plugin: ServerManagment.dll (1.0.1548.25234) loaded.
[2004-03-28 21:35:55] Plugin: XactProvider.dll (1.0.1546.35315) loaded.
[2004-03-28 21:35:55] Plugin: ZipcodeProvider.dll (1.0.1546.35316) loaded.
[2004-03-28 21:35:55] Replay Network Server Emulation started.
[2004-03-28 21:35:55] Starting configuration server on 127.0.0.1:8923
[2004-03-28 21:35:55] Loading server plugins.
[2004-03-28 21:35:55] Starting ntp proxy server.
[2004-03-28 21:35:55] Starting DNS Proxy
[2004-03-28 21:36:39] Processing ToDo Information.
[2004-03-28 21:36:39] Refreshing RecordingGuide for: wrlwnd2(192.168.1.110)
[2004-03-28 21:36:40] Parsed 14/16 entries.
[2004-03-28 21:36:40] Refreshing RecordingGuide for: wrlwnd(192.168.1.120)
[2004-03-28 21:36:41] Parsed 39/40 entries.
[2004-03-28 21:36:41] Building ToDo List for: wrlwnd
[2004-03-28 21:36:43] WiRNSService.BuildToDo(): System.IndexOutOfRangeException: Index was outside the bounds of the array.
post #43 of 275
Originally posted by wrlwnd
kjac,
wlrwnd,
Your box is having a problem building the todo list. The next version will have a "prep debug database" command that I'll want you to run to send me the db. Other than that all I can say is double check all your settings; if you're comfortable with SQL at all, I'll tell you how to manually run "Prep Debug Database".
-kjac
post #44 of 275
kjac,
i'm midly comfortable. let me know.
i have quadruple checked configs deleted and redone, etc.
wrlwnd
post #45 of 275
kjac,
wrlwnd
wrlwnd,
Get SQLite.exe (http://www.sqlite.org/sqlite.zip) run "sqlite WiRNS.db" and run the following commands (in this order).
DELETE FROM schedules WHERE program NOT IN (SELECT program FROM todo);
DELETE FROM programs WHERE id NOT IN (SELECT program FROM todo);
VACUUM;
This will remove a lot of data from your database; when this is done zip your .db file and your .guide files, and e-mail them to me.
After doing this you'll need to redo a Guide Update otherwise your db will be empty.
-kjac
post #46 of 275
kjac:
I really like the way you've seperated "administration" from "tools"; now it will be next to impossible to choose "update guide" when I meant to choose "channel guide", thanks!
I'm glad that you left the 24 hour clock in, and the < and > are great additions.
Now for the bad news, my todo list is empty, just showing an execution time. Here's the error I get:
Code:
[2004-03-28 18:26:01] Building ToDo List for: NotTivo
[2004-03-28 18:26:03] WiRNSService.BuildToDo(): System.IndexOutOfRangeException: Index was outside the bounds of the array.
I only have the one Replay (for now) so it's not a multiple Replay problem.
post #47 of 275
Originally posted by Joann
kjac:
Code:
Joann,
The multi replay was a different bug.. do you have a 4k or a 5k?
-kjac
post #48 of 275
Bigj,
-kjac
That worked.
Cool
post #49 of 275
I have a 5K.
post #50 of 275
I have a 5K.
Joann,
If you could try the same steps I gave wrlwnd in http://www.avsforum.com/avs-vb/showt...10#post3591310 that'd be helpful.
-kjac
post #51 of 275
kjac,
file on its way
wrlwnd
post #52 of 275
Joann/wrlwnd;
Fixed; was a bug with theme channels.
-kjac
post #53 of 275
kjac,
you da man. works great:D
wrlwnd
post #54 of 275
Thanks kjac, that fixed it.
post #55 of 275
Glad to hear, any other outstanding bugs?
-kjac
post #56 of 275
Also, some of the menu functions dont do stuff yet; those plugins aren't done (ie; ReplayGuide; this will eventually be a replica of the ReplayGuide on your replay)-kjac
This will be a fun feature.
On the list, I know are also features like;
Headend Remapping Utility, Flexible Recording Setup (G/NG, # of Episodes etc.).
I'm one of the guys that was originally thrilled to just have the Canadian listings. Now this is getting to be a very nice suite of features for the Replay. Hat's off to you Sir!
CLiff
post #57 of 275
It would be nice to have GUI remapping of channels. I am envisioning
something that looks like the replayguide (when you're done with it : - )
that has an extra column called "displayed channel". When a new feed
is added it defaults to the real channel... but on the GUI you can change
it to any number or "NA" for deleted.
That would allow removing channels prior to them hitting the replay
(and then having to delete them there every time a chance is made)
AND it would allow remapping channel numbers so that frequently
viewed channels could sit together in sections :-)
Ehud
p.s. I'm still having the previously described problem. I HAVE added
the replays but without Serial#s. Could that be related?
post #58 of 275
Ehud
markus,
Which previously described problem?
-kjac
post #59 of 275
post #60 of 275
markus,
Follow the steps: http://www.avsforum.com/avs-vb/showt...10#post3591310
and get me the data.
-kjac
  Back to Forum: ReplayTV & Showstopper PVRs
This thread is locked
