Originally posted by LJCullen
Got the Pace Box yesterday -- I throw out a few questions --
A) I have a "cable" connection for Digital Audio out -- the pace box offers an optical output which my AMP will handle fine -- is there a difference in the quality of the connection??
B) Was there a problem last night with sound on NYPD Blue on the HDTV side -- ?? Just my luck -- I get a new box and am now wondering if it was the network, the feed and/or the new box. I got HBO SHO fine but some of the network HDTV channels were low and/or missing. Had a few "adult beverages" out last night so I did not trouble shoot it then -- but am fixing to do battle now if I was the only one with the problem.
To answer your questions:
A) The 'cable' connection you are looking at is called a COAX digital cable out or SPDI/F connection. Most Dolby Digital receivers have at least one of these connections on it. As for quality, the industry will argue this one until they are blue in the face, but technically, yes, the COAX connection is better, allowing more data IF YOU USE A HIGHER QUALITY CABLE to connect your box to your receiver. Will you HEAR a difference? Not likely unless you have a SERIOUS amount of money tied up in your system.
B) I can't speak for the sound loss during NYPD Blue, but most audio dropout problems are caused by bad data being sent to the box. Usually, changing the channel will fix the trick, and sometimes, the box requires a reset.
Hope this helps.
Fred Forlano
