Originally Posted by
Nayan
Wasn't there a TNN long ago, which is now Spike? Looks like they are bringing it back I guess.
EDIT: Just did a quick search and it is coming back. They will be on Comcast later this month and select Charter areas.
Yes, the "new" TNN is being marketed to broadcasters to be used as a subchannel. Its carriage on cable systems will totally be a negotiation between the broadcaster and the cable company. Note that Brighthouse retransmits local stations fairly intact. Those using QAM tuners will get all the subchannels a broadcaster carries, whether that subchannel has a dedicated cable channel or not. Though, in my experience, a new subchannel generally gets a BHN cable slot not long after its introduced. I would imagine that's in the carriage agreements.
NOW.. let's try to keep this thread on topic. As mentioned, before, it's a BRIGHTHOUSE thread.
