AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Orlando, FL - BHN
Orlando, FL - BHN - Page 10
post #271 of 18584
Greg,
Any possibility of getting HD TBS or TSS on BHN?
http://www.turnerinfo.com/newsitem....a3-bd665bb00fa3
post #272 of 18584
Rob,
Don't count on getting anything produced by Turner South.
From the news article you linked to they don't provide any programming to Florida:
Turner South, Turner Broadcasting System, Inc.'s 24-hour regional entertainment network, presents a mix of original programming, movies, regional news and sports to cable and DBS affiliates in Alabama, Georgia, Mississippi, South Carolina, Tennessee and regions of North Carolina. The multiple Emmy-winning network also offers games from the Atlanta Braves and the Atlanta Hawks and is the official home of the NHL's Atlanta Thrashers. For more information, access the Web site at turnersouth.com.
post #273 of 18584
Yeah no Turner South in Florida....
post #274 of 18584
Except on D*. But that is another thread, I believe.
post #275 of 18584
Originally posted by Marshall
My HDTV has been in the shop since December, that is another story... When it returns to my home Saturday, what is the OTA situation here in CF now, mid June 04? I am asking this to avoid seeing a week signal notice on my RCA 100 STB and spending hours moving the antenna just to find that you guys already knew the station was down... If this is answered somewhere else in this board, please point me there.
Marshall,
Best of my knowlege, there are no major issues regarding the HDTV OTA signals out there, except for the usual low power from PBS Orlando (Ch. 24). There is another thread devoted specifically to the OTA situation here in Central Florida:
http://www.avsforum.com/avs-vb/showt...7&goto=newpost
Also, you might want to check out www.antennaweb.org to get the best aiming instruction for your antenna. A great resource which will help you get that antenna tuned in to the best signal possible.
Hope these bits of info help.
Fred Forlano
Higher Definition
post #276 of 18584
Nope, it is controlled by ZIP code and DirecTV will not allow that channel in Florida per their agreement with Turner.
post #277 of 18584
Bummer. There is still hope for TBS, however. Also, it might be possible to broadcast the HD Braves games on a "special events" channel like TWC is doing in some areas. See:http://www.avsforum.com/avs-vb/showt...hreadid=411514
post #278 of 18584
Is anyone else getting crappy reception (again!!) on WFTV-DT on BHN?? I can't get a picture for more than a second or two before it blocks up and goes away. The last game was like this also. Is this a local problem or an ABC problem?? Someone needs to get this fixed.
post #279 of 18584
I will answer my own question, I guess. I rebooted my box and it works fine. Wish I had thought of it sooner. Wonder if the box is going bad? Well at least I get to see the last 6 minutes in HD!!
post #280 of 18584
Anybody noticed that the 5.1 DD audio from WFTV is actually 4.1 since there is no sound from the front channel? I was watching the NBA game tonight and noticed that despite the logo "circle surround 5.1" on the screen. I thing this is a problem with the local station. I have 2 different setups with 2 different receivers/TV and both had no center channel sound.
post #281 of 18584
Actually it's only 2 channel stereo. (It's just transmitted in a 5.1 stream with 4 channels silent)
"Circle Surround 5.1" is used to transport 5.1 channel sound over a normal stereo path.
My solution to the situation was to switch my FusionHDTV to 2 channel sound from S/PDIF and use my receivers Circle Surround capability to extract the 5.1 sound.
So the problem isn't with WFTV-DT. Still, if they wanted, they could set up a Circle Surround decoder to extract the 5.1 sound and then pipe the output into their Dolby Digital encoder so we wouldn't have to do any work on our end.
post #282 of 18584
Thanks Kid. Both my receivers (2 different brands) do detect a dolby digital signal and a 4 separate channels coming in. When the signal is stereo my receivers indicate a dolby prologic sound. Exactely the same happens with channel 6 WKMG. If they are sending 4 channels , why can't they send 5?Your solution is a good one , though.
post #283 of 18584
Does anyone know how much Olympic coverage NBC is planning in HD?
Not to answer my own question but i found this info. Link
post #284 of 18584
Hi all, haven't post in quite a while...
I'm moving, and I have a BHN installation question that hopefully gmclaughlin or someone else who has gone through this may be able to help me with.
My new house has a media panel (structured wiring) with I believe a 6-way video splitter in it (not sure if it's amplified or not). I have one single RG6 run from outside to the panel.
I know that BHN charges PER ROOM to install. Do I order a single-room install, or is the purpose of the per-outlet install so that they will SERVICE that many number of outlets if there is a problem?
Based on my past experience, I'm hesitant to just ask a CSR this type of non-standard question. Any info that you all could provide here would be appreciated.
Rich
post #285 of 18584
Rich
Rich,
I can't speak to the ordering issue you asked about, but wanted to drop a note to check that amplifier and make sure it is a bi-directional amp. Most 'builder' installers put the cheapest thing in they can find, and most times, it is not a bi-directional amp. It is necessary to have a bi-direcitonal amp if you are using any Brighthouse box, since they need to talk back to Brighthouse for things like activation and to get guide information.
Just a thought to consider.
Fred Forlano
Higher Definition
post #286 of 18584
If you are getting any STB's or a cable modem the install is going to be included with the hardware, epically with the cable modem since they are required to bypass any amplifiers. Last time I checked they do not charge per room if they don't install STB's and if they don't have to run any wire. For example, if you were getting standard cable they should only charge you for the connection since you already have everything else.
They typically run specials for the install if you get digital cable and roadrunner, so I bet you can get away with a full install for very little, just don't let them try to charge you for connecting drops or for hooking up standard cable beyond the standard connection fee.
Anything else, Greg?
post #287 of 18584
Yeah Fred is right, and if you don't have what they need they will give you an amp. They should leave your house with everything working. No need to go out and buy another amp. I don't even put in amps, BHN does a good job of it
post #288 of 18584
thanks for the info Fred.
I suspect it won't even be an amp at all, just a simple, cheap splitter that requires no power whatsoever. I suspect this as I've had to argue with the builder already about my need for a duplex receptacle in the panel which they've yet to pull wire for. The question I posed was what did they think I was going to do with all of the cat5 that goes there without any 110V power. I'm think hubs, routers, amplifiers, even a place to put wireless hardware...all kinds of reasons. One without power seems kind of silly to me.
What I don't understand about your post regarding the bi-directional amp is whether or not an amp is required for hi-def. I have BHN's HD box right now, but I'm in an apartment and have no idea what the wiring and other hardware is there.
If the builder gives me a simple splitter, will I have to get some kind of amplifier?
EDIT:: Oh yeah, I have the cable modem already. Wife just called me, and she's already contacted BHN Apparently there is NO CHARGE whatsoever for a transfer to new house as I'm already a customer. If this is true, then this is a new and improved TWC, er, BHN than I'm used to from long ago (some of you may have read some of my dated rants on the subject). Hopefully I'll have 110V should I need amps or whatever
post #289 of 18584
An amp is not necessarily required. BH will do whatever they need to get your install working. If that requires an amp the will put one in. If they need power and there is none at the panel they will use a power injector that comes with the amp. If they say its free let them come and do what they need to do I doubt you will have a problem. Hopefully you will not get a contractor.
What area are you in? I might be able to give you a contact if you have any problems.
post #290 of 18584
Thanks Peter...
New home is in the southwest Orange County master-planned mega-development Horizon West. South of Winter Garden, north of Disney. Okay, okay, as much as I hate to say it because it sounds so stuffy, it's in Windermere there I said it (wife is quick to point that out, LOL)
I'm certain that once I get in and stick my antenna in the attic for OTA I'll have more questions about that A bit further away from the towers than I was in Ocoee, and my antenna was outside there.
post #291 of 18584
I second letting BTH do the install. I had 12 drops put in to wire every room in the house. cost me $10 a drop for the 8 drops that were new. They provided everything amps cable, wallplates. They ran a whole new line from the street to the house to tie in to the common ground. then the installer spent nearly 4 hours in my attic pulling cable.
NOTE
Make sure your builder is using RG6 cable for all pre installed coax cable. I think BTH will only use RG6 or better for digital installs.
post #292 of 18584
Peter I wish I had know a week earlier that you were doing VOOM installs. I would have had you do mine. No complaints, I would have just liked to throw the business your way.
post #293 of 18584
Thanks Rudy. Let us know how you like Voom!
On the type of cable, not that I am telling anyone to use it, just don't want to scare anyone. There is nothing wrong with RG-59. For cable's purpose it works fine and carries all of the channels they need, including those in the digital area. RG-6 is preferred not necessarily because of its extended bandwidth but because of the decreased signal attenuation over long runs. That's why BH uses RG-6.
post #294 of 18584
As I mentioned in my first post it's really just 2 channels encoded in a DD 5.1 (not 4) stream. (If you put you ears to the center channel and rear surrounds you won't hear anything.) I realize it can be confusing as your reciever's telling you it's a true 5.1 stream, but the proof is in the listening.
That happens because the 2 channels are actually transmitted via a DD 2 channel stream and not "wrapped" in a 5.1 stream like WFTV does 24/7 and WKMG does on occasion.
And to answer your final question they can (and do) send 5.1 audio, but the network source material has to originate in 5.1 (all ABC sitcoms and dramas do, no CBS shows do for the moment).
post #295 of 18584
Thanks again Kid. Iguess I get the picture now.
post #296 of 18584
Rich
I just moved into a home in November that we had built with structured wiring and distributed audio going into a master panel in the garage. The builder's contractor ran all the wires and made all of the connections except the onr running from the street to the cable junction outside the house. When the BHN contractor came out to connect the cable, all he really did was run the cable from the BHN street box to the outside of the house. He did a good job but on the order sheet, he wrote down the 13 coax outlets that I have. My fist bill from BHN had an additional activation charge of about $60 for that when all the guy did was run the outside cable. The builder's AV contractor was there at the time and made sure all of the jacks were activated. The BHN contractor did not do that.
I called BHN for a waiver and they had to send another company rep out to verify that only 4 outlets were active before they would waive the extra fee. So not only did I have to take 4 hours off of work to save $60, but I'm sure it cost BHN more than $60 to send the guy out and verify that only 4 outlets were active. Further, I don't think the guy had much clue concerning structured wiring because I had to point everything out to him as to what cable ran where.
Anyway, the point I'm trying to make it to pay attention to what the BHN installer writes on the order form as to active outlets, or you might also get hit with an extra fee that the contractor did not earn. Still, I think BHN should have credited me the $60 and not have to send a rep out to verify it.
post #297 of 18584
Do we have est. date of when the HD recorder on BHN??
PLEASE ADVISE!!!
post #298 of 18584
Best guess on the SA8000HD from BHN is around mid August.
post #299 of 18584
It has been my experience that if all Bright House does is come and run a drop from their tap to the side of your house (demarc) they should not charge you anything for how many live connections you have in the house. You should not have to pay a thing if they don't have to run any wires. That's what you pay the builder and his subcontractor for.
Sounds like in Gilley's case, it was a BH contractor taking advantage of the situation, as they probably do in many situations like that, and BH sent someone else out to audit the contractor as they often do.
post #300 of 18584
But I still had to disconnect all of my outlets, except for the 4 with TV's connected, or BH was not going to waive the outlet activation charge. Of course, I have since reconnected the outlets in case I want to move a television to a different outlet.
Just keep an eye on the BH contractor and what he writes down on the paper.
