Originally posted by plasmamaniac
For a while AOL was blocking my email notifications and I had to have them allow email from AVS. I don't know if this could have been your case but it was in mine. How's reception in Fayetteville. I've got great reception in Peachtree City now that I cut down some trees.
Reception is good at my place overall.
The only channel I can't really get is TBS.
And tonite, ABC was very spotty b/c of the high winds.
All other channels have good reception it seems, and the only factor seems to be high wind speeds.
I have some trees that I would like to come down, problem is they are right by a creek bank in my backyard (hard to get to and cut down).
I know you have a rotator on your antenna, can you tell me what setting you have it on for receiving TBS? Does it tell you actual degrees like on a compass? That might be helpful.
thanks,
jb
