AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Atlanta, GA - OTA
Atlanta, GA - OTA - Page 14
post #391 of 3205
Come over and help me hack around with my 2 HDTivos, please.
post #392 of 3205
Originally posted by jackshakes
from the sound of things you're pretty close to all the antennas too ... check www.antennaweb.org for sure but i'm pretty sure an indoor antenna would be just fine.
you can order the silver sensor from solidsignal.com as well as other places:
http://www.solidsignal.com/prod_disp...T=&PROD=ZHDTV1
a lot of people talk about the radioshack double bowtie ... there was a link a page or two back.
You also may want/need an inline amplifier too. Try without and see how good the signal is.
The Ratshack Double Bowtie has worked pretty well for me indoors considering that I am over 30 miles from downtown. Cannot get a peep out of the new PBA 30 HD broadcast though. Bummer.
post #393 of 3205
DDisney,
What part of Atlanta are you in?
post #394 of 3205
Yeah, HEy DDisney, i see you too are a Disney Fan! Disney Rules!
Thanks everyone for the help. I think we will try the Silver Sensor and see what we get with that.
Mike
Downtown Atlanta off Ralph McGill
post #395 of 3205
Originally posted by rdwalt
DDisney,
Lawrenceville
post #396 of 3205
Mike
Well, it's easy to be a Disney fan when that is your name.
post #397 of 3205
HI,
Im new to HDTV. I just got the LG4200 OTA recceiver and looking for a good antenna. From where I live (2 miles west of I-85 in Suwanee) is there a good indoor antenna. I just pluged a pair of rabbit ears in and can pick up ABC, NBC, CBS, and PBS with around 50% strengh. I just cannot seem to pick up FOX.
Thanks for any help.
post #398 of 3205
I am about 1 mile inside 285 near Northlake Mall. I have a DISH 6000 receiver and Channel Master Antenna. After tweaking the antenna I get all the stations at about 85-90 signal strength EXCEPT NBC Channel 11 which is about 65-70% strength and has a ton of drop outs. Suppose I could climb in the attic and tweak the antenna to improve NBC signal strength but would have to tweak back to get the others.
Is there another solution except tweaking each time or trying a rotor? Is it possible to have two antennas in the attic where I have an additional antenna that is aimed right at the NBC tower to get good strength and then to split the two antennas together? And for down the road when I might have two HD TV's then how do you send OTA signals to two TV's from an antenna? Is a high quality spliiter the answer there also?
But the main question is how do I get NBC right now since if I tweak the antenna to get NBC then it drops all the others very low on the signal strength. I think I may be too close to the antennas where minor adjustments cause major changes in signal strength.
post #399 of 3205
NBC is a VHF signal as compared to the rest which are UHF. Could this be your problem? What kind of antenna do you have? Is it a CM 4228?
post #400 of 3205
I will have to check the exact model # but the installer did say it was just a UHF antenna and not VHF. It is a square/rectangular flat antenna about 3 feet square. I was getting NBC in the mid to high 70's signal strength but FOX and CBS were much lower and barely coming in. By adjusting I now have FOX and CBS and ABC and WB and PBS all in the high 80's signal strength BUT the NBC dropped to mid 60's from high 70's signal strength so now I have NBC going in and out. Would getting a VHF only antenna to get NBC signal then splicing that into my UHF antenna line possibly work or does splicing two antenna's together do strange things? Thanks.
post #401 of 3205
I believe that you have the CM 4228 which is a very good UHF antenna which under ideal conditions can pick up VHF but it is not very reliable for VHF. You might email or call solidsignal.com and ask them their opinion of the 4228 as regards to picking up VHF reliably. They are a sponsor in this forum. You also can PM them here as a member named solidsignal.
post #402 of 3205
you could also get a vhf only antenna and combine the two signals ... someone else would have to tell you the best way to do it as i've never done it.
post #403 of 3205
Hey guys...is PAX (14-1) down? I did a rescan yesterday and the station is locked in but no signal is coming through. Can someone take a look please? Thanks.
post #404 of 3205
any places in the north atlanta area to buy a cm4228 for a decent price?
the antenna I have isn't picking up fox reliably an I desire to have it going by sunday
post #405 of 3205
Never mind. PAX seems to be back up. Now ABC News on 2-2 seems to be offline. Is it just me? What's up?
post #406 of 3205
ABC News on 2-2 no longer exists. My understanding is that ABC only has it available through their website
post #407 of 3205
I didn't really watch it so it's not much of a loss but the channel is still open (for lack of a better term) and the tuner stops there when I channel up or down. It shows a black 4:3 screen with gray bars on the sides. I cannot delete this channel without deleting 2-1. It's not a big deal. Maybe they'll use the space for something more useful.
post #408 of 3205
I bought the RCA D903 today and hooked it up to my silver sensor and my dish box, and this unit might be broken but it didn't work, @ all, didn't pick an kind of percentage @ all, what do you guys use to boost your signal? Any suggestions, preferrably something that doesn't take ac power but I will get one that requires it if it's the best, thanks
post #409 of 3205
I have a Radio Shack "High-Gain Signal Amplifier" (stock no. 15-2507). It's advertised with a typical gain of 30dB VHF/UHF. It's a powered amplifier where the AC plugs into your living room wall outlet (i.e. way downline from the antenna). It makes a dramatic difference in my setup - I have a ChannelMaster 4228 antenna in the attic, about 70-80 ft coax cable run from the actual amp & TV. I have also heard very good things about the ChannelMaster 7777 amp, but I personally have not tried it. BTW - the Radio Shack unit was last year's model so I got it at a reduced price.
post #410 of 3205
I live in Powder Springs and I need recommendations for an antenna for OTA.
I have Directv-HDTV 2 recievers. In the bedroom I have the silver sensor, it's pretty good on most local HD channels except CBS. Just got the other reciever for the tv room. Now I want to put an outside antenna so I hook both recievers up to it. Any one live close that could either stop over or recommend an antenna?
Denny
post #411 of 3205
The only 2 places (decent price ) Are Fry's at GPM and Dow electronics on Boggs road.
Denny
The Atlanta mantra is buy a 4228. It will even pick up WXIA for you.
post #412 of 3205
thanks thepicman, I thought that this would be the one. CM4228
Denny
post #413 of 3205
With the CM4228 do I need to also get the CM 7777 amp?
I plan on getting these today .
thanks
Denny
post #414 of 3205
I'm getting the CM4221(3021) which is about half a CM4228 and half the price. I'll try installing in my attick next weekend with no amp. I'll post the details afterwards.
Currently I have a pair of rabbit ears in the attic and I pick up NBC, ABC, FOX, PAX with no breakups pending good weather - UPN, TBS, TBN with minimal breakups but no CBS. I'm right off Acworth Due West near Stilesboro Rd about 25 miles from the towers.
post #415 of 3205
thanks
Denny
You might need it and you might not, only trial will say for sure. Many use it (me included, but I am far away), some had it overdrive some of their channels. I would buy it personally, but Dowdoes not take returns.
And twice the install if you have to replace it with the 4 bay.
TPM
post #416 of 3205
Originally posted by thepicman
...And twice the install if you have to replace it with the 4 bay.
TPM
HA!
What install? I'm just tossing it into the attic. but you have a point. I'm counting on the 4221 being a tad better than the rabbit ears.
post #417 of 3205
thanks
Denny
I would. I have the same antenna and pre-amp setup in my attic with great results.
Also see the following local Atlanta PBS web site and their recommendations for OTA for the Atlanata area:
http://wabe.org/tv/dt21.html
post #418 of 3205
Hey Everyone, decided to register and subscribe to this thread (finally) since I check it every day at work!
Live in the Roswell area on 92 and believe that I may be addicted to HDTV!
Have Direct TV with a Panasonic 42 LCD. Had the 360 reciever but changed it out for the RCA, which has been suberp thus far.
Most of my locals come in okay, fox comes in from ny on 88.
I never get tbs in, as a matter of fact I took it off my channel list and occasionally ABC can be a pain. My attenna is from Direct TV.
My two cents: last night the audio was messed up on NBC during joey and will and grace, not like a kung fu movie but in the sense that the laugh track was much higher than the rest of the audio. However, that problem was corrected before the apprentice started, and i assume it was an nbc issue not a reciever issue.
anyways thats all, ill chime in when needed.
....Joe
post #419 of 3205
OK, I got the antenna at Fry's, they didn't have the amp. This needs to be speacial ordered. So I called Dow's and they wanted over $90.- for the amp. What a rip off.
I will try the antenna and if needed will order the amp online.
thanks for your help.
post #420 of 3205
$90? Must be gold plated Mine came from here.
http://www.solidsignal.com/prod_disp...=&PROD=ANC7777
