AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Norfolk, VA - HDTV
Norfolk, VA - HDTV - Page 264
post #7891 of 7950
"SKY4TV" WSKY in HD has been readded to DirecTV...
post #7892 of 7950
Thanks Robert
post #7893 of 7950
yay do they show Tides games in HD?
post #7894 of 7950
are any of the local channels going to pick up me tv
post #7895 of 7950
maybe...
post #7896 of 7950
If anyone is interested, religious programmer Daystar has flipped their analog signal to digital on channel 25 (WVAD-LD/25-1 Chesapeake)...
post #7897 of 7950
DirecTV could be ready to launch 8 new HD channels...
post #7898 of 7950
HLN, Cooking Channel, Lifetime Movie Network, History2, ID, TVLand, Encore Action, Independent Film Channel...
post #7899 of 7950
i just bought a house in va bch. wheh i move i will have a choice of fios directv or cox and i am leaning toward direcrv second woud be fios.
post #7900 of 7950
I have had DirecTV since 10/2004 dumping Cox. When FiOS came available, I took their Internet (dumping Cox HSI) but have kept DirecTV. I know I'm paying more than having it bundled but DirecTV was and still is way ahead of Cox and FiOS TV when it comes to their receivers. REALLY like the Whole Home DVR. ALL the receivers are interconnected...
post #7901 of 7950
i had directvf from 1996 thru 2003 when i sokd my house in brigadoon.had the gabo receiver then went with ttivo then the r15 dvr.thats ehen i sold my house and moved big mistake
post #7902 of 7950
i have had D* 2001 love it!
the new genie dvr looks cool!
post #7903 of 7950
Well you know where my vote is going to go. I would say the Trio system is pretty good & with the TRUE 6 tuner DVR coming soon that is a big plus. HSI speed increases?? wink.gif
post #7904 of 7950
metv is now on 13.3
post #7905 of 7950
What's going on with WVEC's sound? Surround sound is not working properly -- no rear speakers and sub shuts off. Only getting left/right audio. Had this issue with them a couple years ago before I got them to fix it. This is the only channel that does it to me and it does it on both Vz and OTA on more than one TV / Receiver.
post #7906 of 7950
Is this throughout the day or during primetime?
post #7907 of 7950
Sinclair Broadcast Group's "MyTVZ" WTVZ (33/MNT) Norfolk is FINALLY showing syndicated programming in HD... #hrva #VARTV
post #7908 of 7950
There is hope for Sinclair's ABC and MNT in the Greensboro NC market! (WXLV and WMYV)
post #7909 of 7950
They're still doing SD syndication?
post #7910 of 7950
Yes. SD during weather crawls and dispute crawls, too. The local news on ABC45 is SD widescreen. It's not even theirs - it's News14 Carolina from Time Warner Cable. I have seen Jimmy Kimmel in SD and other random non-primetime ABC shows in HD. Thank goodness I can get WTVD OTA.
post #7911 of 7950
Wow...
post #7912 of 7950
Looks like this thread is pretty quiet. Hopefully someone will see this....
Suddenly, after years with no issues, I cannot get channels 13-1, 13-2, or 13-3. All other local OTA channels are fine. For reference, I'm using an OTA antenna installed in the attic.
I sent an email to WVEC's tech, but got an automatic reply saying they'll be out of the office until October 10th. What?!
Anyone else having problems getting these channels OTA?
post #7913 of 7950
I watch OTA with no issues...
post #7914 of 7950
Strange after all this time I suddenly cannot get those channels OTA. frown.gif
post #7915 of 7950
No issues here either.
post #7916 of 7950
I'm having the same problem. When rain fade wipes out my Directv I switch to OTA. I cannot receive WVEC-13. It used to come in fine but even moving my antenna it is not there. All the other channels come in fine.
I'm in North, Va which is in Mathews County. About 47 miles I think.
post #7917 of 7950
I'm a bit closer than you (Hampton), but I checked again this morning and still cannot get it. Again, all the other OTA channels work fine. The cable connections to the TV seem fine; I'll check in the attic as well, but I would think if it were a loose connection issue that I would also have problems with the other OTA channels.
PS - I tried another TV in the house; it does come in on that TV (connected to the same antenna), but the signal strength is low and drops out. Prior to yesterday I had no issues with either TV. frown.gif
post #7918 of 7950
UPDATE:
Channel 13 suddenly reappeared today and appears stable. I still have no clue what happened. confused.gif
I did get a response to my email to WVEC saying nothing has changed on their end, ie signal strength.
post #7919 of 7950
I see that WVEC is doing a make over on their news set
Does this mean they are finally going to show the news in true HD on Channel 13 now?
I hope they have upgraded the cameras
Aren't they running 16x9 SD currently?
post #7920 of 7950
Last I noticed they were still broadcasting the news in SD. I hope they finally upgrade to HD.
