Originally Posted by
CmdrTekno
I am also able to pull in the RF 41 translator off an old powered UHF loop "rabbit ears" @ about 80% on the LG zenith converter box! The same rabbit ears setup is unable to lock on the whsv RF 51 translator so kudos on the strong signal.
ComdrTekno,
Your tests would seem to confirm that the ch 41 antenna is working properly and delivering the planned signal coverage. Channel 41 was chosen because it would allow NBC29, Wx+, and CW29 to radiate the maximum of 15,000 watts across Augusta Co and southern Rockingham.
In April, when channel 30 begins operation from Massanutten, also at 15,000 watts, all of the Central Shenandoah Valley should receive good coverage. In Crimora, you may even receive a stronger signal from Massanutten.
Thanks for the signal reports.
29Guy
