Quality, not quantity, right?
Currently Available
KAMU-DT - PBS
12-1/15-1 (12) 1080i - national PBS feed
Tower - 3.2 kW, Hensel Park
Contact - Jon Bennett, Station Manager
Ph# 845-5611
KBTX-DT - CBS
3-1 (50) 1080i - mirroring analog 3
3-2 480i UPN
Tower - 25 kW, Carlos
Contact - David Cooper, Chief Engineer
Ph# 846-7777
KYLE-DT - FOX/WB
28-1 (29) 480i - mirroring analog 28
28-2 720p - mirroring KWKT-HD/Waco
Tower - 1 kW (soon to be 5 kW), N Bryan
KWKT-DT (720p) will soon be a subchannel for KYLE-DT, and the power increased to around 5 kW. KYLE splicer acquisition pending.
Contact - Lou Strowger, Chief Engineer, Duane Sartor, General Manager.
Ph# (254)776-3844
Temple/Waco - Central TX HDTV Status
Houston - Tower Power - This should give some idea of what it takes.
Cox Cable
700 KAMU - PBS-HD
705 KWKT - FOX/WB-HD
710 KBTX - CBS-HD
720 KRHD/KXXV - ABC-HD
730 KCEN/KMAY - NBC-HD
732 ESPN-HD
734 Discovery HD Theater
735 Universal HD - rebuild
736 INHD1
738 INHD2
740 HBO HD
742 Showtime HD
744 Starz HD - rebuild
Cox's HD-DVR is now available in the B/CS market.
Contact Form
The Not So Near Future
KRHD - ABC
Digital broadcasting from the local Bryan tower is under consideration.
25-1 720p - mirroring analog 25
25-2 480i - Telemundo
25-3 480i - Weather loop
Tower - 250 kW, Moody
Contact Form
Ph# (254)754-2525
KMAY-LP - NBC
This KCEN translator station will most likely be upgraded when the switch date is put into play.
Tower - N Bryan
Contact - Gerald Richmond, Engineering
Ph #(254)859-5481
Cox Cable
ABC(KXXV/KRHD) should be on Cox in time for the Super Bowl.
Verizon - FiOS TV
We're still not on their list.
Old pseudo-College Station thread
Please let me know about any new or bad info.
-Brian
Currently Available
KAMU-DT - PBS
Ph# 845-5611
KBTX-DT - CBS
3-2 480i UPN
Ph# 846-7777
KYLE-DT - FOX/WB
Ph# (254)776-3844
Cox Cable
700 KAMU - PBS-HD
710 KBTX - CBS-HD
732 ESPN-HD
736 INHD1
738 INHD2
740 HBO HD
742 Showtime HD
Contact Form
KRHD - ABC
Contact Form
Ph# (254)754-2525
KMAY-LP - NBC
Tower - N Bryan
Ph #(254)859-5481
Cox Cable
Verizon - FiOS TV
-Brian
I believe the show is Across America.
