On another note, I talked to Lou at KWKT-FOX in Waco again today. We had a pretty good conversation, he was actually rather informative and understanding. However, it's not looking good for FOX-HD here in Aggieland.
I was mainly interested in what constituted full power for their new transmitter, since, as I explained, we still could not receive KWKT-DT here and it appeared the FCC had them at 1000kw. He said the 1000kw is for channel 44 when they transition to analog cutoff, and for now the FCC only allows 300kw on the channel 57 DT antenna. The bad news, if it really matters for us, is he has learned that channel 57 is also used by a Houston area (Baytown?) station operating at 5000kw. Now, I'm not sure offhand just why that affects Waco, but he implied that because of this the FCC is considering making KWKT-DT drop their power even more, down to 200kw!!
I even had you Cox lovers in mind.
I quizzed him about Cox picking up their signal, and he informed me that he had talked to Cox about putting something (a dish?) on Cox's tower to get it, but Cox didn't want to do it. We both agreed the HD situation here was frustrating, being sort of in a no-man's-land. He said it was for them too, since throughout their corporation they have spent several $million on HD and don't feel like they get any return on the expense.
I was mainly interested in what constituted full power for their new transmitter, since, as I explained, we still could not receive KWKT-DT here and it appeared the FCC had them at 1000kw. He said the 1000kw is for channel 44 when they transition to analog cutoff, and for now the FCC only allows 300kw on the channel 57 DT antenna. The bad news, if it really matters for us, is he has learned that channel 57 is also used by a Houston area (Baytown?) station operating at 5000kw. Now, I'm not sure offhand just why that affects Waco, but he implied that because of this the FCC is considering making KWKT-DT drop their power even more, down to 200kw!!I even had you Cox lovers in mind.
(I wouldnt shed a tear if that happened, but something tells me wako fox and abc would.... they can keep kcen, imo they are overall better with hd than kprc, in fact overall i would say kcen is the best local channel sans pbs, that actually switches to the right feed usually, especially with reruns.... kbtx is really really bad about switching to the hd feed sometimes)
