If your going to paint directly onto the Drywall using a Roller, your making a very adequate choice. It's a great place to start out from for a NooB, pretty much assuring one of a successful effort the first time out of the Blocks.
Emphasis on "first time out..." , naturally.
I have drywalled deep red walls and a white ceiling. All controlled lighting and will have the PJ at around 16-18ft. The screen size will be based on the exact placement but hopefully big
. I have 8ft celings and viewing distance will be around 14-16'.
. I have 8ft celings and viewing distance will be around 14-16'.Well, to start, you cannot place the HD66 at 18' unless you can opt in for a 140" diagonal screen....which is not advisable on a wall where you only have 96" height the place a 70" tall image. The big reason being the HD66's Image offset. You'd have to mount the PJ with it's feet almost on the Ceiling...and still tilt considerably and use a lot of Keystone correction.
I could see you using a Chief RPA Mount w/dedicated Flat Pj mounting plate (Gives you approx 6" between Ceiling and PJ) and barely getting it accomplished, but another issue is those White Ceiling Tiles.
No, you need to limit yourself to 120" diagonal and that means your Throw distance can be at most 15' and no less than 13" 5". Not a lot of leeway there to work with.
I need to go basic for the first screen to get my feet wet and am thinking SS is the way to go to start.
Any tips on settings to use with the HD66 and SS?
You'd better get to where the thingee is actually up there before concerning yourself about calibration. We/you can address that at the proper time, once you have an image to adjust.
Also I have a beam that runs 10" down from the ceiling is this going to be a problem at that throw distance?
At least the Optoma's Image offset helps in that regard, As long as you can place the PJ so it's offset also allows for that 10' obstruction (...and it should do that easily enough...) it should present no worries. All you have to do is allow that your NOT going to use a Image size...at a location that places the Top of the Screen withing 11" of the intersection of the Screen Wall and the Ceiling.
If there ever was a time to place the PJ and use the image shot upon the Wall to guide you in masking off an exact area to paint, this is certainly such a time.
Thanks for the help
Thanks for the help
The real test will be if you still are giving out "Thanks' after you absorb everything and readjust your thinking.
But your welcome...as far as things go at present.
This is my first PJ so I need some help
