AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Greenville, NC - HDTV
Greenville, NC - HDTV - Page 174
post #5191 of 8693
Pulled in some distant stations tonight,
Believe it or not
4.1 WJXT-HD Jacksonville Florida
4.2 WJXT-SD
4.3 WJXT-LA
5.1 WCSC-HD Charleston SC
6.1 WECT-DT Willimington NC
6.2 WECT-WX
4.1 WCIV-DT Charleston SC
13.1 WVEC-DT Hampton VA
26.1 WSFX-DT Willimington NC
26.2 WSFX-TUBE
post #5192 of 8693
5.1 WCSC Charleston, South Carolina
10.1 WAVY Norfolk, Virginia
13.1 WVEC Hampton Roads, Virginia
CW 27 analog from Norfolk
tonight... Have received the digitals before, i just don't think i've ever posted it and the cw 27 is a new one
post #5193 of 8693
Originally Posted by jamieh1 View Post
Eastern, can you pass along to Bertie all the recent post by others that are now hearing the audio problems Ive been mentioning for a few weeks now.
I will pass along, jamie. Question for you, is it only during CBS HD programming? Or do you notice it during CBS SD as well? I watched Big Brother tonight and didn't notice it.
Ironically, a power surge is what killed the audio encoder for CBS that had to be replaced last time. Now, the CW is out... I'm kinda getting tired of the power surges and I don't even work with the equipment engineering does... Imagine how they feel.
post #5194 of 8693
Eastern, I believe the problem is only occurring during HD programming, and it doesn't have to be in Dolby 5.1 like with Y & R.
post #5195 of 8693
Ive mainly noticed during non local programming, (CBS) Ill monitor for the next little while and see if I hear it during the noon news.
post #5196 of 8693
Did'nt notice any audio issues during the noon news, but as soon as the CBS feed kicked in at 12:30, the the bad audio started.
post #5197 of 8693
I picked up on that as well Jamie. It sounds like they are sending audio to my home via a string with a cup on their end of it, and a cup at my end! LMAO (sort of like a hollow sound and garbled at times)
post #5198 of 8693
Just got in from Raleigh, went to see WWE Raw at the RBC Center, great show, sat behind the production crew and it was awesome watching them control all the lights, music, pyro. Real hi-tech equipment. Large HD video screen was super clear.
Walked in the building and was given free passes to the upper level, Lexus club, pre raw reception, free food and drinks. Very fancy area, LCD tv's mounted all over the club, all the ESPN HD channels, were being shown.
Great trip.
post #5199 of 8693
The CW is back on the air, Directv's feed came up a couple of hours later.
Alot of audio skips today on WNCT-DT.
post #5200 of 8693
The audio encoder for 9.1 is being rebooted today. If you have a chance, listen tonight and see if you hear the problem.
post #5201 of 8693
8:00pm sharp when CBS feed came on the audio issues kicked in, probally as bad as Ive heard yet.
post #5202 of 8693
Yes, I heard it too. Well, that's one piece of equipment to cross off the list.
post #5203 of 8693
Well, as I indicated in an earlier post, my Dish Network DTV Pal certainly picks up quite a few channels (and shows programming info for PBS 25 with no need to use the TV Guide option). However, after noticing that the timer feature wasn't coming on when I indicated, I discovered that the unit's time was set wrong (hour early). Problem is, you can't set the time. You simply give the unit which time zone you're in, and whether you're currently in daylight savings time. That's it!
It turns out, the DTV Pal gets its time from the TV channel you're tuned to. I've tuned to NBC, CBS, FOX and PBS with this box (can't get ABC with the rabbit ears at this point). I'm not sure who's clock is wrong, but it always seems to be 1 hour off. There is no manual time set feature. So I have to set the timer for the unit to come on in the mornings 1 hour early and pray that the stations don't adjust their time!
Elsewhere on AVS, it seems I'm not alone. A lengthy discussion is ongoing with the glitches of this device. The time setting feature is the biggie. There is no real way to update the software on these boxes. I just hope the locals can set their clocks correctly so that devices like these will be set properly. I also hope Dish will take my boxes back and send less-buggy ones with manual time set!
post #5204 of 8693
Anyone else getting signal drops on WITN-DT.
Im getting a 90-95% signal and every now and then it drops to 0% for a split second.
post #5205 of 8693
jamieh1, well, after going through about 20 links in the chain, it looks like engineering found the source of the audio problem. We expect the problem to be fixed tomorrow or friday depending on how fast CBS can get the equipment to us. Thanks for beating the drum on this one.
post #5206 of 8693
No problem thats what we are hear for. Glad that you guys found the problem.
Any sign of Directv folks at the station installing any local HD equipment?
post #5207 of 8693
IIRC, they were here a month or so ago, but I'm not sure if that's what they were working on. I'll ask and see if anyone knows.
post #5208 of 8693
Eastern,
When you see Bertie and the crew there, tell them that the HD group on here really appreciate all the time they take to check out the problems we pick up on and post. I know it must have taken several hours for them to go through all that equipment to find this one little glitch. I try not to jump to conclusions when I notice something, and give it time before I jump on the board and say there is a real problem. Things sometimes work themselves out, but in this case it went on for a while. It's good though if we can to get all the little bugs figured out before everyone starts turning digital, because they will have their hands full with all kinds of questions there I bet.
Ken must be working really diligently on his control panel still. We haven't seen him post for quite sometime.
Thanks again.
Thanks again.
post #5209 of 8693
Originally Posted by brewtus00 View Post
Originally Posted by chcbb View Post
Anyone heard anything about Suddenlink adding more HD channels in Eastern NC? I'm moving to the area and am not sure if the landlord will allow a dish, so I'm probably going to go with cable for at least a while. Someone on another site (broadbandreports) said they heard about Sci-Fi, FX and USA on 7/1.
according to the info channel on suddenlink they will be adding all those HD channels you listed plus Chiller on channel 216.
Any more word on this? Rumor was they would be adding them on 7/1, but it never seemed to happen.
post #5210 of 8693
They did add them, Ive got them on my channel lineup
post #5211 of 8693
What are the channel numbers for you for Sci-Fi HD or FX HD? They aren't showing up anywhere on my guide (the HD channels are in the 700's).
post #5212 of 8693
12 is frozen on my TV.
post #5213 of 8693
Same here, looks like Tums Quik Pak is getting a long advertisement.
12.3 is working.
post #5214 of 8693
Getting WAVY 10-1 Richmond/Hampton Va
WHRO 15-1, 15-2, 15-3 Hampton Va
post #5215 of 8693
718 USA HD
719 Sci Fi HD
720 FX HD
post #5216 of 8693
I have not seen these channels either. I just did a reboot on my cable box and still don't have them. I am on Suddenlink from Greenville.
post #5217 of 8693
Those channels aren't showing up at my place either (Suddenlink in Greenville). I guess they have more bandwidth available in La Grange than Greenville? Very odd. I might have to give them a call. FX and Sci-Fi definitely have some good shows, plus USA will be part of NBC's Olympics coverage next month, which would be great to have more of in HD (http://www.usatoday.com/sports/olymp...schedule_N.htm)
EDIT: If you go to suddenlink.com and type in La Grange's zip (28551), 718-720 do show up in the HD BASIC channel line-up, but they don't when you put in Greenville's (27834). Oh well.
post #5218 of 8693
Well, the saga continues with the Dish Network DTV Pal (analog to digital converter with timer and program guide). It turns out, the device gets its time from digital stations it tunes to. When I set a timer on the DTV Pal to turn itself on at a specific time, etc., it relies on the time that it is given by the digital TV channel it is tuned to.
WITN-DT's PSIP (Program and System Information Protocol) clock is 1 hour off, based on what my device is receiving. Other channels in the area seem to be sending the accurate time. WITN is not the only one with this problem, based on comments in the very hot AVS Dish DTV Pal forum. I suspect this issue will get worse as more people start buying these converter boxes that pull the same info and have timers.
I hope someone from WITN checks this forum and is able to adjust their clock ASAP. I believe that in 2005, the FCC required PSIP for all off-the-air digital broadcasts, and requires the clock be accurate.
post #5219 of 8693
Anyone else not getting WRAL's 5.2? It seems to have completely gone for me.
post #5220 of 8693
The 'Raleigh, NC - HDTV' Thread has had some chatter over there about overall issues with WRAL OTA over the past day or so. Maybe someone over there might make contact with 'RAL about this issue and have something to report.
