AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Greenville, NC - HDTV
Greenville, NC - HDTV - Page 289
post #8641 of 9110
Originally Posted by AndThenScottSays View Post
WRAL has theirs at the transmitter. That may be a possibility, although the tower in Grifton doesn't have much space around it. If memory serves me right they have cows grazing some of the area where the guy anchors are.
I would assume it's so outdated at this point that it may not be worth keeping, especially if they don't even run it all the time.
I,m thinking u may be right about it being outdated.
post #8642 of 9110
No dolby on Wfxi. wsfx yes.
post #8643 of 9110
WYDO doesn't have Dolby either.
post #8644 of 9110
They still don't have a splicer device on 14 I guess. I checked again later on WFXI (cable signal) and they had turned the dolby on again.
Tonight 9-1 sounds bad to me, but 9-2 sounds much better than it ever has. Still has some slight dialog in the rear at times, but it might be the movie.
post #8645 of 9110
Directv adds ION HD to channel 38 in its local line up.
post #8646 of 9110
Didn't DirecTV do this nationally a few months ago?
post #8647 of 9110
D* informed of ION CH 38 when I called them about something else last Saturday.
post #8648 of 9110
Directv added the national east-coast feed of ION (ch. 305) in HD. Local IONs are hit or miss in HD. Raleigh and now Greenville are HD for example, but my ION (WGPX Burlington for the Greensboro DMA) is not HD on Directv. I have it in HD on Directv via the AM21 tuner. I
post #8649 of 9110
ION CH 305 had been in HD at least the last two months. I know because I had been watching NUMB3RS late at night(0100-0300). Unfortunately DD 5.1 is not available. Furthermore the West feed ION CH 306 is NOT in HD.
post #8650 of 9110
We've had the national feed for several months. They just virtually mapped it to channel 49 (our local ION station). Can also be seen on 305 as you mentioned...
post #8651 of 9110
My first sentence was incomplete.. I meant to say:
Directv added the national east-coast feed of ION (ch. 305) in HD in the first round of the HD additions they gave is last year.
Does the HD Ion that appears on ch 38 or 47 have the hourly ID's?
post #8652 of 9110
Suddenlink still hasn't added the HD feed for CW 9.2 yet. Figured they would have by now.
post #8653 of 9110
My understanding is that if Directv has the actual ION feed from a local market in the local package they are not adding the HD feed to the locals package. Like the Greenville NC and Ral NC market its not the actual WEPX or WRPX feed of ion being shown, show they are remapping the national ION feed to the local #.
post #8654 of 9110
Dont know whats taking suddenlink so long to add CW HD. I have a friend that works for Suddenlink in Greenville and he says no plans as of yet.
post #8655 of 9110
NO WNCT HD CW 9.2 here in Time Warner land either. Their agreement with WNCT is running out as I understand it, so maybe once they renew their contract, they will be able to carry HD then?
post #8656 of 9110
Interesting. The SD Ion used for WGPX does have the WGPX ID's so I guess we won't see it HD (without the AM21) and will just have to use ch. 305.
post #8657 of 9110
I think your right. There are some ION stations out there that do local programming/sports and those DirecTV customers won't be able to see it (unless using an AM21)...
post #8658 of 9110
Wow. I replaced the original coax today on my antenna. 1998. No I get much more, and stronger Sig. Like I used to. Get channels on towers from Marion, dillion, garner, fox 50, which is the hardest for me as a rule.
Very happy!!! The Wingate 8800 is working like it used to.
post #8659 of 9110
What brand of cable? RG6 regular or quad shield? And preamp?
post #8660 of 9110
Chan master RG-6 and the low gain winegard pre amp.
post #8661 of 9110
Are you using the black and red or the blue and black connectors? BTW I'd just bought the wire stripper and the crimping tool.
post #8662 of 9110
I use gold ends. I blew up my pre-amp though after only one day of rewiring... Don't understand why the vhf side went dead. I need a new amp now.
post #8663 of 9110
If you are using crimp connectors, you will never truly get a good connection. Compression connectors are the way to go. Lowe's sells some decent compression tools for occasional use.
post #8664 of 9110
I bought the compression tool for BNC, RCA and F connectors. It's designed for the RG6 and RG59 cable compression fittings. It's very easy to use. After you strip the cable you slide it in with the connector you compress it as you make a fist with the tool wrapped in your hand.
post #8665 of 9110
It's the Winegard 8700 amp that is my problem with 9 and 12. VHF is dead. UHF works fine. I replaced everything possible and no change. So I got 4 months out of this amp. I got more time out of the antennacraft..... Cheap Chinese junk. I did unplug the power before I started taking things apart, in case anyone might be thinking I forgot.smile.gif It worked great the first day like i said above, and then I started having the problem.
post #8666 of 9110
In regard to the pre-amp not passing VHF, I got a couple of UHF/VHF combiners with power passing UHF and just bypassed the amp altogether on VHF. Everything works fine now. I just lost a little signal on the VHF channels, but no issues with dropouts. The Winegard HD 8800 UHF does just fine at 42 miles from Grifton. smile.gif I get 55% signal on WNCT. WCTI I get 68%.
post #8667 of 9110
I use the Radioshack UHF/VHF signal combiner which passes power on UHF. Works great, as the Holland and Pico versions only pass power on VHF.
post #8668 of 9110
post #8669 of 9110
Any comments about the local news anchors?
post #8670 of 9110
I wonder what's going on over at FOX? I see they've changed their logo down in the right corner. I like this one better though I think. The logo on 14 is off the screen some on my TV
