AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Jackson / Meridian, MS - HDTV
Jackson / Meridian, MS - HDTV - Page 3
post #61 of 1837
Has anyone noticed that CBS now is multi-casting on 12-2. We currently have Viper radar being shown. I am hoping that during March Madness they will broadcast multiple games at a time.
post #62 of 1837
how do you get DirecTV to recognize this? i have the HR10-250 HD Tivo...
post #63 of 1837
You may have to do a manual rescan of your OTA channels. It should be in your HD-Tivo's setup menu.
post #64 of 1837
Any word on WLBT yet??
post #65 of 1837
TitanTV's section on digital stations 'coming soon' shows WLBT-DT going live on June 1. They just recently updated the status. For the past year it has been 'waiting for FCC approval'.
post #66 of 1837
Any clue as to why the North Carolina-Wisc game is NOT in HD??/ This is ticking me off. Someone forget to throw a switch or something?
post #67 of 1837
I didn't get home until the Kentucky game, but it was in HD. Strange about the NC-Wisc game - it was in HD @ my in-laws on the Memphis CBS channel.
I did notice that the DD5.1 was not being passed through locally and the sound kept dropping every minute and often several times per minute. The signal strength was fluctuating a lot last night also.
On a side note - did you all notice that our digital channel numbers have been reassigned. We now have FOX showing up as 35-1 instead of 41-2. Makes more sense. Also 41-1 (used to be a duplicate of 40-1) is gone.
post #68 of 1837
anyone have any updates on when NBC and/or FOX will be available in HD OTA in the Jackson area? i heard March for NBC and sometime 2005 for FOX late last year. any news?
post #69 of 1837
NBC is showing 6/1 as the go live date for their digital channel (according to FCC documents).
Both FOX and WB continue to say sometime in 2005. Your best chance for updated news is to go to gomiss.com and email the station managers for these local networks.
They are really good about responding quickly - usually same day. It only helps to have more people inquire about HD programming.
post #70 of 1837
Looks like WAPT is keeping up with WJTV. They now have a continuous radar loop running on 16-2.
post #71 of 1837
Hi,
I live in meridian. I am getting a new sony hd plasma tv. Plan on getting dish since they offer it here now with local channels. Local ABC broadcasts in HDTV, how do i make sure I get in hdtv with dish network. I am told I have to buy an extra antanne and digital box just to get it? Wow sure is a waist paying extra to get local channels and that then. I am really confused. Help me out.
Matt
post #72 of 1837
If you want any HD from Dish Network (E*) you'll need an HD receiver from E*. That will let you receive the HD channels from E*, and with an antenna, you'll pick up your local HD networks.
The $5 you pay for locals will give you all the local major networks in SD. The only other option would be to get waivers from your local stations that wwill allow E* to supply you the HD Network feeds out of NY. The guys here may be able to tell you how likely that possibility is.
post #73 of 1837
Title edited (added the Meridian, MS DMA)
post #74 of 1837
So basically since ABC is only one providing HDTV in my area we would only be using the antenna to pick up that station. We plan to get HDTV anyways from dish so I guess we will already have the HDTV box. Would dish be able to help us get it all set up to recieve hd signal form ABC?
Matt
post #75 of 1837
Depending on your location, you may be able to pick up CBS out of Jackson also. Your best bet is likely a local antenna company or the satellite installer may also be able to put up an outdoor antenna.
Also, depending on your location relative to the ABC - Meridian tower - the ABC station may be as simple as a $15 Radio Shack Double Bowtie antenna.
Definitely call up your stations though and inquire about getting waivers so you can get HD delivered via satellite. They obviously won't be the Meridian stations, but at least your network programming will be available in HD.
post #76 of 1837
Thanks for your help. Yea, I am thinking about the waiver thing right now but would like to be able to still get local stations, mostly concerned just to get local abc since I like it. Now if I use antenna to pick up abc will I like have to being switching imputs on tv? Or would it still work going through my satilite box.
Matt
post #77 of 1837
The HD tuner is built into the Dish satellite box. It should be seamless switching between antenna stations and satellite stations. Even the guide will be incorporated.
post #78 of 1837
msett, its good to see someone else on here from the Meridian area. I have an outdoor antenna set up to receive local DTV stations. You shouldn't have any trouble picking up ABC. Let me know how you come out with the waivers from 24/30. Maybe if we both ask, they will listen. After talking to them on the phone, I get the idea that they plan to do the absolute minimum required to comply with the FCC for their HD transmissions.
Our local PBS also transmits HD. Some of their science and music stuff is really improved by being in HD but they are in a different direction from where I live so I have to use an antenna rotor to tune them in. I live in the Centerhill area.
Let me know if I can help with your antenna situation.
post #79 of 1837
Hi ttriplett. I live in Marion/Meridian line. Kinda of between 39 and 45. Anyways what kind of antenna shoud I get? I wont need a big one will I? Is there one I can just attach to my dish when I get it?
Matt
post #80 of 1837
Matt, there are units designed to attach to your dish but I can't vouch for their UHF performance (never used one).
Since you seem to be fairly close to the towers, an indoor antenna might work just fine, especially if there are no hills blocking the way. A good one to try would be the Zenith Silver Sensor (I saw one at Sears). It is inexpensive and has good UHF performance for an indoor unit (all of our local DTV stations are on UHF). That might be a good starting point.
post #81 of 1837
Has anyone else lost their digital feed of Fox 35? I read the earlier post about the channel re-assignment but lost the channel entirely about that time. I still get WB on 40-1. I did rescan for digital channels but it's still not showing up. I live in Brandon, on the reservoir and can pick up all the channels OTA both digital and regular with an attic antenna except for Fox. The picture quality on the digital was much better than what I receive over the satellite.
post #82 of 1837
35-1 and 40-1 have become very weak over the last week. I can not lock onto a reliable signal anymore. CBS, 12-1, is also fluctuating for me. I tend to usually have a good signal, but it has been dropping for a brief second more frequently - and my signal strength has been moving around. My fear is the trees have all leafed out and they are affecting my signal.
post #83 of 1837
Since I am the Chief @16, I will be glad to answer questions anyone has when I have the time. Currently we are transmitting the most power of any of the digital stations in town. WMPN-DT is higher on their tower than our antenna is on our's so that helps them. Fox is also up around 1800 feet on Ch. 3's tower so even though they do not have much power, they cover fairly well especially since they are not transmitting HD. Our antenna is at 682' on our tower and eventually will be at 931', almost at the top. However, tower structural issues kept us from putting the antenna at the top just yet. We have to move an FM antenna to make the move which will not happen for several years. However, the good news is we will double our transmitter power July 1st, which should help some. WMPN is where they will stay. WLBT will eventually be on 9 but I have heard they will move to ch. 7 when WDAM in Hattisburg stops analog transmission. Ch. 12 will be full power very soon since they are installing their permanent transmitter right now. They have been operating a small transmitter from their studio tower at less than 400'. Their Raymond tower is around 1800 feet & I am not sure where they plan to put the digital antenna out there but it should be way up. I was proud that we had 5.1 audio very early on since it was so expensive to pass along from ABC. We have run one HD program locally several months ago called Remarkable Journey but it was not a very good representation of good HD. There may be more as long as it is just one show. I do not now why your reception of WAPT-DT would change from day to day as we are not having any problems I know of. I have to turn the transmitter off completely when anyone climbs the tower to fix things but try to keep that to in the mornings. Thanks for letting me in on the forum and I look forward to have more of you watching and giving me feedback.
Tom
post #84 of 1837
Glad to see actual people in the know coming on the boards. Really makes things special.
Tom, you'll be glad to know that I'm in Hattiesburg and can pick up 16 on a good night, 8-bay CM with pre-amp. Shouldn't have any issues after the power doubling in July.
[SHAMELESS PLUG]
I had mentioned it earlier in the thread, but thought I would let everyone know. The company I work for has officially opened the new Player's Audio Video on Lakeland. It's in the same shopping center with Cellular South.
Stop in and play with are new toys. We've got AMX and Vantage running the store with a DVHS loop of OTA stuff and a Xperinet Mirv DVD system, a huge speaker wall with instant switching that I'm pretty proud of, and a Runco/Rotel/B&W/Stewart theater that kicks butt.
If you're feeling like a high-roller, bring some CD's into our 'Champagne Room' that has a complete Macintosh preamp/SACD combo with two 500watt monoblock's running a set of B&W 802D's... The room really needs some wall treatments, but still sounds sweet.
Tv's on the floor are all Mitsu's, 50" plasma, 42" & 55" CRT, and a 62" DLP..
Stop on by and have some fun.
[/SHAMELESS PLUG]
Kevin D.
post #85 of 1837
Tom
Thanks for the information. I second what Kevin D. said about having people in the know on this board. This is just what we needed.
WAPT-DT is by far the most powerful signal I can receive (I'm in Ridgeland, west side of I-55). Your HD has been very impressive. I do have a question regarding DD5.1 programming. Does ABC have any prime-time shows recorded in DD5.1? Also - with you being in the business, have you heard if/when some of the other networks will begin to pass an HD signal? NBC on June 1? What about WB/FOX?
Thanks again for your work. It is very much appreciated by all of us HD enthusiasts out here.
post #86 of 1837
ABC does alot of programming with 5.1 but they have also installed something to make even stereo programming "fill" the rear channels. I have considered doing this locally since the sound is so "dead" when we go back to our local upconverted signal and it is just stereo. It will be a long time before we could actually make real 5.1 audio locally. Also, have not heard when NBC or Fox/WB will be doing something different. I would think NBC would get something on in the next few months. They are supposed to be on July 1 but they are good at STA's (authority to hold off doing anything) so who knows. I hope LBT's HD looks better than their analog channel. The quality there is horrible, I am sorry to say. Lots of motion artifacts for some reason.
tom
post #87 of 1837
hey guys,
question........
i have a hr 250 hd pvr direct box and rescanned for OTA locals and now have 35-1 WUFX fox local showing in my guide, BUT no programming info at all just "regular schedule".
I thought it may take a day or two to fill in the info but it has been at least two weeks and nothing, same listing, "regular schedule"??? even went through the guided setup twice since then and still no program info in the guide.
Is there something i am not doing in the hr250 menu or setup? or has direct tv and their guide service just not been updated yet?
I can see the programming info for 35 from direct tv sat channel and is the same but without the guide info for 35-1 ota it will only let me record off of it for 30 minute blocks or by doing it manually.
Would prefer to watch wufx over the air even though not true HD. The wufx 35 over direct sat seems to have audio sync problems especially on nascar.
Also getting "regular schedule" for 20-1 and 20-2.
post #88 of 1837
I have the Hughes HTL-HD D* receiver and the program guide data is exactly the same as yours. I'm not sure from where D* pulls their guide data, but they are not up to date on all of our digital channels. 20-1 and 20-2 have been this way for over a year and 35-1 since day one.
post #89 of 1837
thanks for the reply SF.
now at least i can complain to direct tv and say we are having guide problems in our dma for some of the ota channels.
Got an email response from the manager at WUFX and he said they would be going true HDTV.... "as early as July or at the latest Jan 2006".
Hopefully WLBT going hdtv is less than a month away now.
post #90 of 1837
Tom
What will it take to keep WAPT from switching to SD format when you have weather alerts on screen - or are showing election results? Tuesday was real annoying having the programming switch from HD to SD every couple of minutes when you showed the updated results of the election runoffs. And then tonight we missed the entire HD broadcast of 20/20 because of the weather warning icons on screen. Just curious...
