I am looking at the Panasonic based Yamaha S2300MKII
for its automation potential. It is on the JVB list of SDI modifiable
players. |
Thanks. I took a quick look at the serial protocol. As usual, it's an incomprehensible block of goop that will take a couple days to understand, but it looks comprehensive. It might be a good alternative.
I got a reply back from PMS, which was basically "Whatever is wrong is not our fault". I sent back a reply indicating that I don't really care whose fault it is, or even if there is a fault, but that I'm not going to spend money on it unless I know it works and perhaps they might want to try it and find out so that they can know whether they should sell it to customers of the HDL or not.
I don't think it should require a business genius of my stature to figure that out. The HDL is obviously going to be fairly important in the crowd who would give a crap about SDI. So you'd think that they'd want to work out any issues and at least verify compatibility, or lack thereof, so that they could indicate that to potential customers.
I'm guessing I won't even get a reply back, but we'll see.
