AVS › AVS Forum › Video Components › Video Processors › SDI dvd players
SDI dvd players - Page 14
post #391 of 408
I have also just bought an iScan HD with SDI and am thinking about a new DVD player to SDI mod. If you buy a cheaper DVD player the issue I am having is that the sound may not be as good but you are paying more money for a player with better sound and video but benefiting only from the video if you do an SDI mod
post #392 of 408
Another consideration is how much do you want to spend when you will void the warrenty when you have it modded? 3910 at $1300-probably not. 2910- at $700- better.
post #393 of 408
Could always wait a year until the warranty expires
post #394 of 408
Or you could buy a less expensive refurb which only has a 90 day warranty... ;)
post #395 of 408
Atman, Just so I understand your new product: I could store my DVDs on my hard drive, use an interface like Meedio to select a movie, and the Xcard will output via your SDI card to a SDI capable scaler? Does this mean I could watch the movie on my projector via the SDI output to the scaler, and simultaneously use my computer to do other things via the video card's output to my monitor? Have you compared the video quality to that of a standard DVD player modded with SDI out? I apologize for bringing up some HTPC questions, but my thread in that forum sunk fast.
Eric
post #396 of 408
lambe,
You could use Meedio, albeit I would probably use something like TVedia as it supports the Xcard natively (meaning you get full OSD displayed through Xcard and scaled/processed by your scaler), and yes it would allow you to use your monitor output for something else simultaneously.
I have a RP82 with SDI out, and I have the Xcard with PDI fed into a H3DII card - the quality is virtually the same as far as I can tell after calibration (this test being an eyeball test via SE 2HD and 61" Vutec Silverstar)
That being said, the navigation issues with the Xcard really bug me, most of the time it works, other times it loops and I have to force it into chapter menu and go straight to chapter 1.
-pd
post #397 of 408
Thanks for pd's explanation.
In general, Xcard's digital video output is very good, it has CUE (chroma bug) though. Fortunately, many SDI scalers can mask the chroma bug.
post #398 of 408
I am about to get a demo Theta Carmen, is it still up to date video wise, particularly with SDI option ?
Here the SDI upgrade costs more than the demo unit, how much is it in the States, is there a DIY SDI option for this unit... :confused:
Thanks...
post #399 of 408
Check with PMS Video (aka Pixel Magic). If it needs the BT656 kit, it's $150 US. If it needs the BT601 kit, the price is considerably more.
post #400 of 408
Sorry, I dont understand how a PC card will work on the Theta Carmen... :confused:
post #401 of 408
I am pretty sure they are talking about these SDI Modification kits from Pixel Magic
BT656 Pro kit
http://shop.pixelmagicsystems.com/in...products_id=24
BT601 Pro kit
http://shop.pixelmagicsystems.com/in...products_id=30
post #402 of 408
Hmmm, I see, the first link looked like a PC card... :o
Do you think this will fit the Theta Carmen, apparentely their SDI upgrade costs 2400 euro... :rolleyes:
post #403 of 408
You might try contacting JVB Digital, they have an office in the Netherlands or MSB Technology in USA,
http://www.jvb.nl/jvb.asp?cur=2&leve...page=contactus
JVB Digital, how to contact us.
http://www.msbtech.com/sdi/
SDI VIDEO UPGRADES
post #404 of 408
Thanks guys...
post #405 of 408
The price of the kit will be determined by the output from the MPEG decoder. If it conforms to the BT656 standard, the price is $150 US. It it doesn't, you will need the BT601 kit -- and that kit costs more.
From what I've read (another mod site), before serializing the MPEG decoders output for SDI transmission, the BT601 kit converts the output to the BT656 standard and that's why it's more expensive.
post #406 of 408
Both are way cheaper than Theta´s upgrade...
post #407 of 408
JVB Digital is super fast BTW, less than a day to do the mod on my 5900, it spent 4 times longer just in transit to and from..:p
post #408 of 408
I am already in touch with JVB, they say if it is Pioneer inside there is 85% chance they can do it...
Anyone knows wich Pioneer is the Theta Carmen based on... :confused:
  Back to Forum: Video Processors
This thread is locked
