Originally Posted by
joe57777
Hi Video Bruce,
I am very interested any local station in Canada that carries the Global TV network. I live in Rochester sort of close to Sea Breeze and I was wondering what kind of antenna you are using to pick up that fussy Global channel? And do you think if you bought one of those advertised power UHF antennas or something similar that you would possibly be able to clearly pick up Toronto or some other Canadian city's local digital off air channel that would carry that Global channel you talked about? Also, I would think that off those local Canadian TV channels that you might be able to pick up some hockey network channels like TSN as well?
I don't monitor this thread. I just saw your post. Never heard of this Sea Breeze, had to look it up. There are two Global networks. Which one are you interested in?
What is your elevation above lake level? Is Toronto is out of range even though it is entirely over water?
The Toronto area recieves Rochester stations only in the summer during tropo, but they are not reliable here. So you might expect the same in reverse.
No the same situation. There is a
huge difference in height of the Rochester stations cluster on that 'mound' compared to height of the CN Tower.
As much as I'm not a far of those Antennas Direct, their 91xg would probably be your best bet though reception for CFTO physical channel 9 would suffer.
Edited by videobruce - 3/27/13 at 5:55am
