AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Carver RH17 Remote
Carver RH17 Remote
post #1 of 4
Looking for a remote, working or non-working..for a Carver CT17 Preamp
Or, a Carver PRH-1 Universal Remote
post #2 of 4
RemoteCentral has IR codes for universal remotes:
Link
HTH.
post #3 of 4
bdfox18doe, is the ct 17 still working ? I've had mine since 1990 still working . Look on ebay the ct17 comes up every now and then ... Rit
post #4 of 4
RIT,sorta..
the pads had worn out on the volume control, so I took it apart, and cut
the rubber pad between the 4th and 5th row, and flipped around. This moved "bad" buttons to key's I don't use. So, I should now be able to get another 15 years out of it hopefully. But If I can get another one I probably will. Found several Carver remotes on Ebay, but none of this one yet.
This thread is locked
