Originally Posted by Calaveras
KVOR and KMAX are now tied for king of the band from Walnut Grove, both are exactly the same strength on the analyzer.
I noticed that KOVR is very clean on the analyzer. On KMAX I can see the signal leaking past the mask filter below -45 dBc. On KOVR I can't see anything at > -60 dBc which is the noise floor on my analyzer.
This made me curious about KTFK, your channel neighbor, which is now 20 dB weaker than KOVR. Its SNR was never as good as KOVR and I wondered if it might be getting a little interference from KOVR since it is so much weaker. Right now both KOVR and KTFK have the same SNR of 25 dB. I would expect this since both antennas are on the same tower and the channels are adjacent. The multipath should be about the same. I'll be checking this over time to see if it holds up.
Chuck
Chuck
KVOR? Another new station I wasn't aware of
Btw, KTFK has also increased power or will soon be increasing power. I know the new transmitter was being constructed a few weeks ago.
