Originally Posted by
CalaverasÂ
KPIX has not filed for a license to cover so it seems unlikely that it could be them. KMSX Sacramento is on 42 so it's most likely them in the valley. I can see a very weak signal from them here. Farther south it might be KVHF in Fresno on 42.
Chuck
The fixed antenna is pointed to Walnut Grove and shows zero signal on RF 42. Also some stations listed from Walnut Grove are zero signal too. KRJR-LP 24 (44-1) I didn't see that one.
The antenna is like a channel Master CM 3018 ( 6 VHF elements on each side, 12 total in a vee pattern.) Small UHF yagi in front.
I see some signal on RF 20 and RF 23 but no lock with the antenna fixed in that position.
I see 45% signal on RF 43, and shows 12-1 & 12-2 (The CW10) ? some repeater for CW channel 10 ?
CalaverasÂ
There are a bunch of low power analog and digital stations that can be received in Roseville including K04QR on RF 4. A friend of mine in Placerville just tried to receive Reno VHF and was unsuccessful so I wouldn't expect to see any of those. Crossing the Sierra crest is difficult. He does receive most of the Sutro stations. It looks like KICU and KQEH should be possible in Roseville.
Chuck
I see the following Analog, 6, 15, 17, 32 those are the strong ones, possibly more.
It locks on RF-3 (Spanish 33) and RF-4, The antenna is not pointed to those stations.
Analog 6 is a screen saver with basically nothing. weak signal.
No signal on 7,8,11 or the Reno ones. No signal on 12 KNTV
No signal on 32 KEMO (co-channel) analog problem
No signal on 36 KICU
All Walnut Grove stations were rock solid. KVIE the strongest at 96%, then KXTV 92% then the UHF stations, 75% all + / - average
RF-3 45% RF-4 55% RF-20 15% RF-23 15%
Most likely alot more if I moved the antenna.
This is not my place, so I am basically trying to copy cat the cable tv system locals with no dropouts in service.
I will be returning in a few weeks, to work out the issues I found.
I will bring a portable antenna, battery tv, and more testing
