AVS › AVS Forum › Display Devices › Direct View (single tube) CRT Displays › New information on KD-34XBR960
post #1 of 160
Okay, I just got an email from a friend of mine with this link
The good news is that the 2nd generation Super Fine Pitch has been enhanced with 28% reduction in beam spot size, higher contrast, brighter picture, and sharper focus.
EDIT:
The price will still be $2200 MSRP.
Here are the specs from the link:
Dimensions
39 1/8" x 25 5/8" x 23 7/8" (994 x 652 x 605mm)
Weight
TBD
Features
Steady Sound® Automatic Volume Control With BBE® Audio Effect
Auto Mute Tuner
Auto SAP
Audio Output (Variable/Fixed)
Auto Channel Program
Caption Vision (CC)
Channel Fix
Channel Label
Channel Skip/Add
Clock/Timer Two Event
Energy Star® Compliant
Favorite Channel With Preview
Front Button Menu Control
Picture Freeze
Channel Jump
On Screen Display (English/Spanish/French)
Program Paletteâ„¢ (Vivid/Movie/Standard/Sports)
Tilt Correction
Scrolling Channel Indexâ„¢ System
Sleep Timer Function
Speed Surfâ„¢ Channel Selection
V Chip Parental Control
Video Label
Wide Modes: (Normal/Full/Zoom/Wide Zoom)
Super Fine Pitch MICROFOCUSâ„¢ CRT
incorporates smaller phosphor particles and a thinner phosphor layer over Sony's previous MICROFOCUSâ„¢ picture tubes, to achieve a 28% reduction in beam spot size. The result is a sharper focus, higher contrast and a brighter image.
Digital Reality Creationâ„¢ MultiFunction V1 Circuitry
raises standard definition signals to HD quality to display clear, stable images from any video source.
CineMotionâ„¢ 3-2 Pulldown
improves the display of video programs originally shot on 24 frames per second film preserving the integrity of the original film frames for more fluid motion and more fine detail.
HD Detailerâ„¢ Wideband Video Amp
has a higher (or wider) bandwidth frequency rating, ensuring that the fine details contained in the original source make it all the way through the set and are displayed on the screen.
Dynamic Focusâ„¢ Circuitry
Dynamic Picture Circuitry
Trinitone® Color Temperature
ClearEdge VMâ„¢ (Wideband Velocity Modulation Scanning)
Vertical Aperture Compensation
Vertical Center Adjustment
3 D Digital Comb Filter
Auto Pedestal Clamp
Auto White Balance
High Voltage Regulator
HD Detailerâ„¢ Wideband Video Amplifier
TruSurround™ SRS® Audio Processing
Hi Scan 1080iâ„¢ ; Display
Clear Edge VMâ„¢ Wideband Velocity Modulation
HD Detailerâ„¢ Wide Band Video Amplifier
Super Fine Pitchâ„¢ CRT
Specifications
Power Requirements: AC 120V 60Hz
Component Video Input (Y/PB/PR): 2 Rear
Composite Input: 1 Front/3 Rear
HDMI: 1 Rear
S-Video Input: (with detection) 1 Front/2 Rear
Control S: 1 Rear
Audio Output: 1 Rear
Monitor Output: 1 Rear
post #2 of 160
If this price is correct, then I definitely will reconsider going for the Sony, especially if the 34" widescreen Panasonic MSRP is $1399. Almost half the price!
A 42" Sony GWIII LCD RPTV would be about the same price as the 34" Sony.
I can't believe the picture will be twice as good as the Panasonic.
post #3 of 160
That site also has the 30XBR910 listed at $2199 and the 34XBR910 listed at $2699. Those prices are B2B, to be used as employee incentives and the like. The retail prices will almost surely be as previously reported, perhaps lower.
post #4 of 160
You didn't really think a brand new Sony TV was going to come out cheaper than last year's model did you?
Does look awesome, though...
post #5 of 160
The price listed is from a link for an incentive. THIS is NOT the price for the PUBLIC!!!! The Publicly released price is $2200!!!! (as stated in the news release).
post #6 of 160
Good. I hope you're right. I want the new 960!
post #7 of 160
Like Jaminson said,
I am not sure about the price tag. But I am going to trust the sony press release for now.
post #8 of 160
if it means anything, the new gamestar magazine has this tv in it, and lists the price as $2200
post #9 of 160
aren't they going to make a 510-like version of this new monitor?
post #10 of 160
Yeah and its called XS-950 I believe with superfine Pitch. XS-950 will replace HS510 and give it a boost in higher resolution...
post #11 of 160
..I can't wait to trade my 34hs510 for the new 960. Has anyone heard if it is still on track for a june release or not?...and one more quick question, is the case pretty much the same as the 34xbr910..thanks, and happy HD viewing!
post #12 of 160
I'm interested in the 960, too, but thinking about waiting until any bugs are worked out. Did Sony make any modifications to the 910s after the initial units were shipped?
post #13 of 160
Powderdog, that's a good question.
Bloated, are you serious? You have the 510 but want to upgrade already? You must be single :)
post #14 of 160
Speaking of the HS510-- a certain big box store, that carries the XBR910 as well, has the HS listed under $1700 on their website... not too bad
post #15 of 160
..rjb, I'm trading my 510 for the 960 due to many replacement 510's from sony...my current one has in the words of the last tech sent out "some of the worst geometry he's ever seen", so sony has agreed to wait until june so i can get a 960 as a replacement..to all those thinking of getting a 510...don't...I really wish i had done more homework before purchasing this stinky 'ol dog!...no adjustable DRC is reason enough not to, even if you're lucky and get a good set with tweakable geometry and good purity...
post #16 of 160
I don't see anything in the specs saying it has an integrated DTV receiver. Was this stated in previous press releases?
post #17 of 160
Does anyone have any information on exactly when the 960 will be in stores? I checked with Tweeters and they did not have it in their computers.
I know June is the release date but does that mean they'll be in the stores in June? If they will be in the stores in the first half of June, would we have heard by now?
post #18 of 160
Is it late this month you'll be receiving the products from Sony or is that the estimated shipping date from Sony? I appreciate the information you've been sharing with us. Thanks.
post #19 of 160
hi guys. i am planning to buy this TV, and went to my local GG and Fry's and asked about when they will be getting them. i told them i heard from the sony website that the release date is june, but then the salespeople laughed and said "yeah right. it'll get pushed back to about august if youre lucky"
im new to this, so is the typical release dates of sony products usually delayed?
post #20 of 160
August is pretty typical, the June date is usually when they start shipping from the factory - there is a lag to get out on display at the retail stores, varies with the store chains and across the country.
post #21 of 160
Nothing against you Joxer, but I tend to disagree.
The new panasonic was scheduled to be released on May 1st. It is in the stores as of a few days ago. Sony is not panasonic, but I think the same should hold true. Does anywhere remember about what happened with the 910 and when that was scheduled to be released?
I read on this board from a dealer that said they are being shipped starting at the end of may.....
post #22 of 160
IIRC, the 910 never really had an official release date from Sony but everyone had assumed it would be released in August due to Sony's history with releasing TVs in the past. The 910 was first spotted in late July and many more appeared in retail stores in early August.
I wouldn't be surprised to see the new 34XBR960 released in June.
post #23 of 160
I just did some researching on this.
The KV34xbr910 was scheduled to be released by sony's press release in
July.
http://news.sel.sony.com/pressrelease/3407
The EXACT day it was available in Circuit City is Aug. 13 (it was in their warehouse a few days earlier)
So it is Possible it will be released in June, however July might be more whats to be expected.
I only researched this one tv set. I did not look into the history of all their sets and there release dates. Im hoping in June..... but if it follows its predessor, then july would be more whats expected.....
post #24 of 160
But it varied across the country, it didn't appear everywhere the same day. I didn't see any in local stores until September last year I remember. Some new models I saw a display model in stores but had waiting lists anyway!
post #25 of 160
I think where I lived, it arrived in August....not sure though.
post #26 of 160
Lets just hope they will be like panasonic and release in June when they said they will be. There is still hope. One dealer in this forum said Sony is shipping the sets at the end of may. I live in los angeles, so I think I would have more of a chance then the smaller cities.... (I hope)
post #27 of 160
I've had five service calls for my 34XBR800 due to purity and geometry problems. The purity was fixed with Sony magnets, even though the green spots will occasionally come back especially if the power flickers and the set doesn't have time to fully power on/off and degauss. The geometry is as good as it can be on this set now after two service calls. There is still a slight bowing at the top on widescreen programs and the left and right sides on 4:3 are a lost cause. The tech said that was the best he could do.
I have not called Sony back yet mainly due to frustration because they seem to refuse to want to replace the set....they just keep wasting my time with service calls.
How did you get them to agree to replace the set with the 960?
post #28 of 160
This experience with the 800 is exactly why I'm leaning toward a good deal on a 910 instead of being first in line for a 960. The 910 seems like proven technology by now, but who knows what issues the early adopters will find in the 960, especially with the major change to a second-gen. SFP tube?
post #29 of 160
Could there be a problem? Maybe.... There was no problems with the 910 when they first came out. If this is the only reason why you will buy the 910 over the 960, Im sorry to hear that. The quality of this set is much better then that of the 910... The 2nd generation display as well as all the additional addons.
My bet is it will be one amazing set!
post #30 of 160
Any new, complicated technology can have unpredicted problems. Cars, computers, TVs...that's why early adopters often complain that they're unpaid beta testers.
This thread is locked
