me> I fail to see the requirement for 5C - unless the DCT won't even transmit the stream to the HTPC.
martyj19> Two strikes. The DCT won't even transmit the stream to the HTPC, and in addition you cannot avoid having to decrypt it in the HTPC because it is sent from the DCT encrypted.
Well, I accept the 1st strike (i.e. the DCT won't even transmit the stream to the HTPC). Guess this works to the JVC D-VHS deck due to some authentication process. Most disappointing - though now that I think about it the Copy Limitation can only be known to be enforced by 5C-compliant devices. Oh, well...
As for your 2nd strike - I think you missed my point. If the HTPC simply never decrypts the content and passes it *back* to a 5C compliant device for recording/display (e.g. the very set-top which streamed it to the HTPC originally), then no decryption in HTPC is required. I would personally be content to utilize the MPEG-2 HL/MP decoding in the set-top rather than dealing with all the hiccups/limitations of similar HTPC-based decoders...
But your 1st strike kinda makes this all moot :-( So much for "fair use"...
