AVS › AVS Forum › HDTV › HDTV Recorders › How to record via IEEE 1394 (Firewire) to Windows XP
How to record via IEEE 1394 (Firewire) to Windows XP - Page 68
post #2011 of 5966
Originally Posted by gsr View Post
Not all tuners support changing the channel over the firewire port, so it's probably important to be specific about which tuner you're asking about. The HD tuner in my Mitsubishi WS-65909 RPTV is one that doesn't support changing channels of the firewire port.
true ;-)
I'm refering to the Motorola and Scientific Atlanta cable boxes that allow firewire control/streaming.
post #2012 of 5966
Originally Posted by lazarus000 View Post
now i get this error message when i try and use capdvhs
80040217 cannot grab samplegrabber
Have you solved this problem? I'm having the same issue.
post #2013 of 5966
So, I used PRM based on a suggestion above on one of my files.
I was able to load it up in Videoredoplus but after a few seconds I get the message "Video Thread: Video Dimensions Change" and then videoredoplus crashes!
I think what happened was I started recording before selecting the file for playback (so, it recorded a bit of normal tv). That change point is what is causing a problem. I can't recapture it via firewire because I deleted it off my 6412 already.
The other error code I am getting with another video file is that it is saying "unable to open <<then the file name>> No data found for requested program(s)"
I tried converting it/fixing it with PRM and MPEG2REPAIR but it didn't help.
I also tried converting using HDTV2MPEG but the problem was that the converted file was just a blank, empty mpeg...
post #2014 of 5966
Hi, I have been able to get this working with a Motorola DCT-6412. However, I am only getting video - not audio. Any idea what I've done wrong? Thanks!
post #2015 of 5966
It worked Very well for me.
I did what it says, at the top and got it first time.
I have tried all sorts before this, and nothing worked.
Im running a Sont MicroDV DCR-IP7E on XP
post #2016 of 5966
no i haven't ... mine is still not working
sorry
post #2017 of 5966
I've got a 3250HD with firewire and WinXP, but I'm not seeing a DVHS entry under Panasonic. I'm seeing:
Panasonic Digital Tuner AV/C Device (TU-BHD100)
Panasonic Tuner AV/C Device
Panasonic Tuner AV/C Device (NV-DH1)
Panasonic Tuner AV/C Device (NV-DHE10)
Panasonic Tuner AV/C Device (NV-HDR1000)
Should I use one of them? Any ideas why I'm not seeing DVHS as an option?
post #2018 of 5966
have you tried using the installer from
http://www.thegreenbutton.com/commun...ssageID=104152
I actually posted the drivers a while back that are included in the install.
post #2019 of 5966
I am using Sonic's Video and Audio decoders. Do you know what decoder is being used?
post #2020 of 5966
Are you installing the driver on the panel device instead of the tuner becuase I get that error if I select the panel device in capdvhs instead of the tuner device.
post #2021 of 5966
Agree. This is a playback issue and likely related to codecs. The Decoder Check utility from Microsoft will at least show what video decoders are installed in your system. I'm using Nvidia PureVideo successfully.
post #2022 of 5966
Originally Posted by IndieRockSteve View Post
Do any XP users have issues changing channels over the firewire port? I'm a MythTV user and many of us are finding we get errors when changing channels. I'm tryng to figure out what the problem is so we can fix it, so I was wondering if any Windows users have the problem?
if you could just PM me I'd appreciate the info!
thanks
I would also point you to:
if you have not been there.
post #2023 of 5966
Digital Video Station MVS-500
mitinc
I can't post links yet as I'm very new here. But a search on those key words will show the STB that I'm looking into.
Has anyone successfully used this to get streams from Dishnet or Adelphia HD Digital cable to Windows XP using 1394??
Would it work??
Thanks much,
-mikey
post #2024 of 5966
I'm getting inconsistent results capturing with CapDVHS. I have to run MPEG2Repair before VideoRedo or HDTV2DVD will open the file. Sometimes I can't open it even after repairing. However I can almost always view the file in VLC Media Player or sometimes HDTV2Mpeg will open it. Any suggestions?
I saw someone talking about PRM is that another mpeg repair program?
Also is there a walkthrough anywhere for capturing transport streams using VLC Media player?
I tried to search for the above before asking without luck...
post #2025 of 5966
Do you have an AC3 codec installed? How are you testing to see if you have audio or not?
post #2026 of 5966
problem solved.
Take the instructions literally. I was using "browse" to find the path to the driver files. I had to *type* the path into the Have Disk dialog, rather than browsing to the path.
Sigh. There's two hours I'll never get back
--jim
post #2027 of 5966
Originally Posted by jaggies View Post
problem solved.
--jim
ok, so do you have the exact name of the driver we should be looking for to manually input it.
it finds the meidvhs driver and installs it fine
its when you get to the "all devices" and then "panasonic" where i can't find the proper one listed.
thanks
post #2028 of 5966
hello I just got my 3250HD today and I am very mad at charter because they disabled the DVI on the box, but any way I deiced I should just use firewire so I found this forum and followed the directions and everything looked like it was working until I got to the point were I had to record with capDVHS I will open the program then go to data info and hit record and nothing happens excpet for numbers moving on the bottom of the app but not the size or bit rate or any of the stuff in the app. then i will try to play the .ts it made with VLC and it does nothing. I can not watch HDTV live with VLC either. any help would be great! thanks
post #2029 of 5966
Ok, so I tinkered and tinkered, but I can't record a valid stream, even from local channels. I've got Comcast with a Motorola 6412 PVR. I'm in Sunnyvale, CA.
I have everything set up correctly as far as I can tell. I've selected Panasonic D-VHS in the device driver and CapDVHS sees the device correctly. When I try to record, it never updates the Data info tab in CapDVHS with stream properties.
Also, I can't play back the files it generates. The files grow as if it's recording (it saves around 2MB/s), but the file is not playable with any players I tried.
I've got a Motorola 6412 box with platform build version 12.13 (May 3 2005)
Looking at the Diagnostic screen of the PVR (pwr - ok) and under Interface Status (menu d11), I see the 1384 I/O device shows:
Active ports; 1
DataXmission: YES
5C Implementation: 0
Loop Status: No
Root Status: YES
Cycle Master Status: YES
Is it true that if the "5C Implementation" is 0, then the stream is unencrypted?
A friend of mine says what I'm seeing is a symptom of encrypted material. I've only attempted to record my local channels, but no dice. Why would my local channels be encrypted?
Does this mean I'm SOL?
Thanks for any advice.
--jim
post #2030 of 5966
well I got it to work with plain digital chanels but for some reason I can get any HDTV. Do you think it could be encrypted or is HDTV in anolog. Is thier a program that will record anolog? thanks!
post #2031 of 5966
This is exactly what I'm seeing too.
--jim
post #2032 of 5966
^^ well i know this app does not record anolog so I just don't know if HDTV is in anolog or digital.
post #2033 of 5966
You don't want HDTV to be analog. That is what it used to be
post #2034 of 5966
so if HDTV is digital that does not explain why I can capture my local HDTV channels.
post #2035 of 5966
Active ports; 1
DataXmission: YES
Loop Status: No
Root Status: YES
I'm in San Jose CA. I subscribed to Comcast Oct15 and until the end of November I was able to capture INHD1, INHD2, HDHBO and all the locals. Now only the locals work for me.
A 5C Implementation value of 0 on the channel indicates the channel can be copied freely.
post #2036 of 5966
I want to be able to transfer the files to a DVD. What is the best way of doing that. I have a 2 hours program and it comes out being 7 gigs of space. I want to be able to burning it to a regular DVD not a DL. Can you tell me what tools to use to do that?
post #2037 of 5966
HDTV2DVD is a new freeware tool to simply convert your HDTV material to DVD. HDTV captures are MPEG-2 Transport Streams at either 1280 x 720p or 1920 x 1080i resolution yet DVD is typically MPEG-2 Program Streams at 720 x 480 (for NTSC). This means that to play HD material on a "normal" DVD player you have to convert the source. This is what HDTV2DVD does in a simple, user friendly way.
Load up your HDTV file (.ts or .tp), start the processing and HDTV2DVD will produce a VIDEO_TS DVD folder ready for you to burn!
http://www.svcd2dvd.com/HDTV2DVD/default.aspx
post #2038 of 5966
I purchased a Motorola Dct 6412/2000 my cable provider says it is the wrong frequency and won't activate it... is this true or are they just lying to me cause they want to force me to purchase a new receiver through them at their outragous price? I hooked the receiver all up and I can view about have of the cable channels with out the receiver being activate with my cable provider... so the receiver must work if I get some channels coming through!??.. I purchased another receiver before this through my cable provider and it is a Dct 6412/2000 and they activated it no problem cause its their own receiver.... I purchased this new receiver privately..and is the exact same model Dct 6412/2000 as the one I purchased through my cable provider.. and they say they can't activate it??? Hmm... Is it true their are different frequency with in the same model of receiver Dct 6412/2000 ?? If so.. is their settings or way to change the frequency in a Dct 6412/2000 to make it compatible to the correct frequency of my cable provider??
post #2039 of 5966
If your cable provider only has the headend equipment for Sientific Atlanta. they will not be able to communicate with the box to authorize channels, map channels, download guide, etc.
post #2040 of 5966
If you read he said he purchased one directly from them, thus unless he lives in Houston, where it supports both SA and Motorola, but TWC doesn't sell their boxes (so obviously he's not there) that isn't the issue.
As he doesn't tell us what market he's in or who his provider is, it hard to tell - but odds are 99% that the frequency excuse is bunk.
Cable Channels are standardized on frequency. Motorola uses the same encryption on their boxes. There is a chart on the Cisco website that has the cable frequencies for each channel (Analog/Digital/QAM) if you are interested.
Now, obviously they would have to to authorize the box to work on their network - changing it from a different network - which is most likely the rub.
  Back to Forum: HDTV Recorders
