Originally Posted by JrCRXHF
Well vividlogic will not suport xp 64 bit so i redid my computer with windows XP then after that i installed the new updates made sure that all hardware had drivers and installed vividlogic 1.1 well i get this looping message that says Vl firebus then under that it says "bus reset storm, bad devices in the network or device connected in loop."
i have tired different ports on the computer and on the TV still nothing seems to work. anyone on here use this software with the mitsu 65731
They're pretty good at email support.
I have been working with them thru email.
I have it recording and playing back.
Right now I need to disable services that hog disk/cpu, but it works.
Try emailing them with your problem.
P.S. They are at v3.02 (unreleased beta) right now.
