AVS › AVS Forum › HDTV › HDTV Recorders › How to record via IEEE 1394 (Firewire) to Windows XP
How to record via IEEE 1394 (Firewire) to Windows XP - Page 115
post #3421 of 5938
When I open vlc and stream ondemand then go to lord of the rings which is 5c=1 in hd it captures about a second of the movie then stops and then I can do the same process over again but with capdvhs open instead of vlc and it records a second of it even though it is 5c=1 has anyone else been able to do this?
post #3422 of 5938
Originally Posted by Erik Garci View Post
The HDCP signal does not contain any flags like DTCP/5C does.
Basically, if an HDMI signal is encrypted with HDCP, then it is always considered "copy never," so it cannot be recorded by any HDCP-compliant device. Otherwise, if it's not encrypted, then it is effectively considered "copy freely," so it can be recorded by any device, even by devices that cannot decrypt HDCP at all.
I suspect that the card cannot decrypt HDCP at all, not even for viewing purposes. If true, I would simply call it HDCP-incompatible, not HDCP-compliant. In other words, the card can only receive non-HDCP signals (i.e., HDMI signals that have not been encrypted with HDCP).
So this sounds like the Blackmagic HDMI capture card would record *nothing* from a Comcast/Moto box, not even in-the-clear channels - since the box doesn't output video at all to non-HDCP displays.
post #3423 of 5938
Originally Posted by tluxon View Post
There's no apparent rhyme or reason that we can make out as to what programs would or should be CCI=2, because we only see it from local stations (but not all - the local NBCHD & ABCHD are still CCI=00x0). ESPNHD, ESPN2HD, UHD, MHD, TNTHD, DHD, INHD (here it's actually a NBAHD, NFLHD, FSNHD and INHD mix), and GOLFVS (Golf and Versus) are all CCI=00x0.
Same here. For some reason 5c=1 on my local stations, yet 5c and CCI = 0 for stations like DHD, TNTHD, INHD, all Encore movie channels...etc...
It makes no sense at all, like someone is randomly flipping switches. I was under the impression that for local hd stations the cable companies were required to leave 5c=0.
Anyways, comcast is soon taking over my area, so it doesn't look too good for the future of my firewire capturing.
On the upside, I finally got HD streaming over LAN working with my Motorola 6200 and VLC.
post #3424 of 5938
Originally Posted by dr1394 View Post
You're looking for the wrong descriptor. You should be looking for the RC descriptor instead. It's tag is 0xAA. The DTCP descriptor is only sent on the 1394 link.
For tools, you can use TSReader:
[Ron
Well, I did get a hold of TSReader and no RC descriptor. Below is what shows for two HD channels from Atlanta Comcast via QAM. Program 10 is the CBS affiliate, Program 806 is NBC, both off the same QAM channel (108). The 3416 shows CCI=0 on CBS and CCI=2 on NBC.
There is no RC (0xAA) descriptor on either, but there is private data descriptor 0XA3 on NBC.
I'm not including it below, but I also checked FOX (CCI=0) which has no 0XA3, and ABC (CCI=2) which does have an 0XA3. So it look 0XA3 is the discriminator in Atlanta.
Is there a tag name for 0XA3 that TSReader doesn't know?
Program Number: 10
Descriptor: Smoothing Buffer Descriptor
SB Leak Rate: 0 SB Size: 0
Descriptor: Registration Descriptor
Format identifier: 0x47413934 (GA94)
Stream Type: 0x02 MPEG-2 Video PID 62 (0x003e)
MPEG Video: Bitrate 38.810 Mbps Resolution 1920 x 1080i
MPEG Video: Framerate 29.97 fps Aspect Ratio 16:9 Chroma Format 4:2:0
Descriptor: Data Stream Alignment Descriptor
Alignment type: video access unit
Descriptor: User Private Descriptor: 0x86
e2 65 6e 67 7e 3f ff 65 6e 67 c1 3f ff .eng~?.eng.?.
Stream Type: 0x81 AC-3 Audio PID 63 (0x003f)
AC3: Bitrate 384 Kbps Sample Rate 48 KHz
AC3: Mode complete main Coding 3/2 5 L, C, R, SL, SR
Format identifier: 0x41432d33 (AC-3)
Descriptor: ISO639 Language Descriptor
Language: eng
Audio type: undefined
Descriptor: User Private Descriptor: 0x81
08 bc 1b 09 1f .....
Program Number: 806
SB Leak Rate: 45000 SB Size: 512
Descriptor: User Private Descriptor: 0xa3
01 65 6e 67 01 00 00 05 50 72 6f 67 31 .eng....Prog1
Descriptor: User Private Descriptor: 0xaa
ff .
Stream Type: 0x02 MPEG-2 Video PID 49 (0x0031)
Descriptor: Video Stream Descriptor
Multiple frame rate flag: False
Frame rate: 29.97ΒΌ
MPEG-1 only flag: False
Constrained paramter flag: True
Still picture flag: False
Stream Type: 0x81 AC-3 Audio PID 52 (0x0034)
08 38 05 00 00 00 .8....
Language: eng
Alignment type: slice, or video access unit
post #3425 of 5938
Program Number: 806
ff.
Um, what about that last line: Descriptor: User Private Descriptor: 0xaa ff?
I would imagine 0xaa is the RC flag and the value "ff" means copy never. Am I wrong?
TSReader doesn't claim to support the 0xaa RC Descriptor tag, so might it just show up as "User Pirvate Descriptor" by default if it's unrecognized?
post #3426 of 5938
Yes, I must be a little blind missing that last 0xaa descriptor.
Also, its there only in the other CC=2 channel the ABC affiliate
Program Number: 3
01 65 6e 67 01 00 00 06 57 53 42 2d 44 54 .eng....WSB-DT
ff .
Also note, that these two CC=2 streams have both an "0xaa" and "0xa3" Descriptor,
and all the CC=0 have neither.
Although "0xa3" is shown as private, I also see it listed in the TSReader reference as ATSC "component name". There are two ascii strings in each, "eng" common to both and "prog1" in the NBC, and "WSB-DT" the station name in the ABC.
I think we have a clue, that whoever is inserting the "0xaa" is also inserting the"0xa3". Still not clear to me who that is. I wonder if the "eng" identifies it in some way.
post #3427 of 5938
It seems likely to me, especially given the results in the SF Bay area, that the 0xaa and 0xa3 tags are being added by your local broadcaster, and the Moto box adds the DTCP tags in order to honor the RC tags. For broadcast content coming from the network, it also appears the flag could come from the broadcast master.
I doubt the 0xa3 is important with respect to the copy protection. It's probably just added for other purposes by the same hardware or software that adds the RC Descriptor.
post #3428 of 5938
The component_name_descriptor syntax and usage is defined in ATSC a_65c (the PSIP specification).
http://www.atsc.org/standards/a_65cr1_with_amend_1.pdf
As ExDeus suggests, it has nothing to do with copy protection. The RC_descriptor is also defined in a_65c. The value (0xff) has no meaning. In fact, on FOX network feeds, you'll see this descriptor with zero length (just the 0xAA). On the Motorola STB's, just the presence of the RC_descriptor triggers 1394 encryption.
BTW, if you capture an in the clear stream on 1394 and run it through TSReader, you'll see the DTCP_descriptor.
Ron
post #3429 of 5938
Since my HDHomeRun will also capture OTA ATSC, I can compare the QAM directly to the ATSC.
For example. for NBC
OTA
Program Number: 3 WXIA-DT
Descriptor: ATSC Component Name Descriptor
Component Name: Prog1
Descriptor: ATSC Redistribution Control Descriptor
ff .
QAM
ff .
So, the same 2 descriptors show on OTA/ATSC and Comcst/QAM, its just that TSReader declares them private and doesn't label them for QAM.
I agree that the ATSC Redistribution Control Descriptor is the critical one, I read in the IEEE paper
http://ieeexplore.ieee.org/iel5/5/33232/01566622.pdf
Redistribution Control Descriptor: The core purpose
for the redistribution control descriptor (commonly referred
to as the broadcast flag), is to signal that the content owner
is asserting his or her rights with regard to redistribution
of the program. The ATSC PSIP standard states that The
descriptor's existence within the ATSC stream shall mean:
technological control of consumer redistribution is signaled.'
The FCC in the United States codified the broadcast
flag in rules that may be found in 47 CFR 73.8 and 73.9 [7]
and 47 CFR 76.1909 [12].
So I guess it comes down to the Atlanta NBC and ABC affiliates asserting the "broadcast flag" and the Motorola 3416 implementing it with CCI=2 over DTCP. Probably these two stations are using a common component (since they are also the only ones with a ATSC Component Name Descriptor) that may default to asserting the RC descriptor.
It would appear that Comcast is not directly involved.
There is however, one Comcast related mystery. As it turns out CCI=2 only shows on only one of the two headends in the area. The Comcast engineer says that both get the same ATSC station feeds and are configured identically.
post #3430 of 5938
I checked out my local channels via Comcast, and only the Fox and (Fox owned) MyNetworkTV affiliates have CCI=2.
I also noticed in the Diagnostic Menu of my Moto 3416, in the d06 CURRENT CHANNEL STATUS page, CCI=0x02 and RC Flag=0x01.
For those with CCI=2, are you also seeing RC Flag=0x01?
My capture over Firewire didn't work (DTCP was enabled by the RC Flag!), and OTA TS captures show the following:
Code:
Program Number: 3
PCR on PID 49 (0x0031)
PMT Version: 0
Service name: KMSP-HD
 Elementary Stream PID 49 (0x0031)
 Elementary Stream PID 52 (0x0034)
Descriptor: Multiplex Buffer Utilization Descriptor
 Bound Valid Flag: 1
 LTW Offset Lower: 180 Upper: 180
Descriptor: Maximum Bitrate Descriptor
 Maximum bitrate: 2025150 bytes per second
 SB Leak Rate: 40503 SB Size: 2048
 Format identifier: 0x43554549 (CUEI)
Descriptor: ATSC Redistribution Control Descriptor  <<<< ---------- RC flag
Program Number: 4
PCR on PID 65 (0x0041)
PMT Version: 0
Service name: KMSP-SD
 Elementary Stream PID 65 (0x0041)
 Elementary Stream PID 68 (0x0044)
Notice only the HD stream has the RC flag. I'd say it's pretty clear the RC flag in a stream triggers the DTCP CCI=2.
post #3431 of 5938
There's no apparent rhyme or reason that we can make out as to what programs would or should be CCI=2, because we only see it from local stations (but not all - the local NBCHD & ABCHD are still CCI=00x0). ESPNHD, ESPN2HD, UHD, MHD, TNTHD, DHD, INHD (here it's actually a NBAHD, NFLHD, FSNHD and INHD mix), and GOLFVS (Golf and Versus) are all CCI=00x0..
My comcast area is the opposite of this. All the local HD channels, ABC, Fox, etc... can be easily captured as they have CCI = 0 but the other HD channels like MHD, UHD, etc... are CCI = 2 and DRM = 1 when looking in the d06 menu of my 3416.
The other digital SD channels are hit or miss it seems like. For example I can't capture the cartoon network, Nickelodean or MTV, but Food TV, CNN and The Fuse Network is ok.
One thing that seemed strange to me was that I could capture all the ESPN SD channels fine, but not ESPNHD or ESPN2HD. They show the same programming so I'm guessing it's the HD part that makes the difference.
I tried to do some test captures last night which lead me to this conclusion. I even rebooted my STB, unplugged it for a few minutes and plugged it back in, to make sure I didn't have some wierd settings set.
post #3432 of 5938
Yes. I just checked all the locals that have CCI set to 0x02, and every one of them have the RC Flag set as 0x01. If indeed the origin of the Broadcast Flag is national, it would seem that some boxes convert that into a CCI=0x02 and some of them do not. Perhaps there is something the local cable companies can do (if they're so inclined) to suppress the STB's built-in "adjustment" of the CCI value in response to the RC Flag.
post #3433 of 5938
I keep getting ERROR:Cannot open output file or ERROR 80040217:Cannot connect sample grabber when using Cap-DVHS. I had this working on a 6412 before, and the box died. I hooked up another 6412, and it will not work no matter how many times I uninstall and reinstall the driver. I'm showing the Motorola device in Cap-DVHS, but it gives the above error(s) whenever I try to use Cap-DVHS. Anyone have a fix for this? It's driving me nuts! I'm using firmware 16.20
post #3434 of 5938
I'm going to start with the obvious: CapDVHS will not overwrite a file that exists. Have you tried deleting the output file or changing the name to a new output file before attempting to record?
post #3435 of 5938
HD or SD i do not have RC Flag=0x01 on channels with CCI=0x02 tho I do have DRM=0x01 on those channels.
post #3436 of 5938
I'm on Armstrong cable in Western PA and seemingly all of the HD broadcasts of the major networks are CCI=0x02 with a mix of RC=0x01. I can record SD channels just fine, but only one or two HD channels are CCI=0x00. This was the first time I set up the FW->PC and I thought I hosed something up, but apparently we're getting hosed from somewhere else
Checked a little closer tonight and it's similar to what others have seen:
Locals that are CCI=0x02 all have RC=0x01.
Stations where CCI=0x02 and RC=0x00 are 5C=1.
post #3437 of 5938
Originally Posted by Paul Chiu View Post
I don't think naming the captured stream to ts, tp, mov, or dvr-ms makes any difference during the capture phase. In fact, you can simply name it 2006-11-15 without an extension.
Later, when you play the stream through various software players like WMA, PowerDVD, or VLC, you will need to rename to TS of MPG.
As for 3250HD and 8300HD working or not. If you are in New York city and Time Warner cable, those 1394 outputs are active on the 3250HD and you can capture using both CAPDVHS and VLC with no problems with no encypted channels.
Is it only true for the 3250 or 8300HD works as well?
With most HD premium channels like HBO, SHO, and MAX, you cannot record anything longer than a few seconds at a time. I think this is due to something in the stream that kills the CAPDVHS or VLC capturing program once initiated.
5c?
If so, wouldn't a DVHS deck work just fine?
I have had HD 1080i recordings that were as long as 5 seconds before termination.
As such, it's a big waste of time trying this firewire recording and recording with the HD-DVR is the only way to go until they have recordable Blu-Ray or HD-DVD machines.
Paul
I failed to see what would change with the arrival of those recordable HD formats when the problem is at capturing...
post #3438 of 5938
I'm still interested in the value of the "broadcast flag" on the troublesome channels. Notice that TSReader shows
ff .
I'm wondering about the "ff" value of the descriptor and what it means.
It seems like the definitive documentation on this that everything refers to is
http://www.atsc.org/standards/A65-B.pdf
which is a members only document., I can't get.
Does anyone have information on the possible flag value, and in particular what "0xff" means?
I'm thinking that an affirmative value of the descriptor is something other than "ff", and that the Motorola implementation keys on the existence of the descriptor rather than its value.
post #3439 of 5938
ff .
I already answered these questions (along with the correct link to a_65), only 10 posts back.
http://www.avsforum.com/avs-vb/showt...&&#post9381047
Ron
post #3440 of 5938
Guys, this is very strange. My Moto 6208 has 5C set at 0 for all of my HD channels. I am able to capture to my laptop for all of them, with the exception of HBO. Unfortunately, my 6208 will not display any CCI information on any channel. I am sure it has to do with the CCI flag. How can I analyze the steam to see what is going on. When I "record", I do not get a 0-byte file. I am afraid to call them, as they just might flag the other 15 channels.
post #3441 of 5938
So, the 6208 doesn't have the same diagnostic screens as the later models?
Using VLC streaming is the easiest way to see which channels you can capture. If it streams in VLC, capdvhs should capture it.
post #3442 of 5938
My 6208 has different diagnostic screens. VLC will stream all HD channels with the exception of HBO. I am probably beating a dead horse here, but I would just love to know what is going on.
post #3443 of 5938
djdrock,
what are the other channels that you are able to record? If it's NBCHD, ABCHD, CBSHD ESPNHD, TNTHD, etc. then I'm pretty sure everyone can copy those. It's the premium subscription channels like HBO that are flagged "copy never" and don't work (as you have seen).
post #3444 of 5938
I can copy Sho-HD, HDNet, HDNet Movies, Discovery HD, Universal HD, MTV-HD etc...I know, it is strange, every channel except HBO-HD.
I have scoured the net looking for similar circumstances of this, and nowhere can I find someone with the moto 6208, has 5C=0, can record all HD channels except HBO-HD. One thing to note, the only non-HD channel that I can record, or see through VLC, is Encore WAM, and one local station. Very very strange. Maybe I shouldn't complain, but wow, this is crazy!
post #3445 of 5938
My 6200 moto box is the same way. I can record INHD, Discovery HD, TNTHD, all Encore SD channels, yet, 5c=1 for my locals, Cartoon Network, and some random other SD channels. I don't subscribe to HDNet, HDNet Movies, UHD, Sho-HD, or HBO-HD so I can't test those out.
post #3446 of 5938
Can someone give a list of Cablevision high def channels that you can archive to PC via this method (also how long does it take to archive a 1 hour high def show?)
Lastly, what's the filesize on a 1 hour high def show?
thanks,
Jon
post #3447 of 5938
thanks,
Jon
I have Cox, not Cablevision. File capture is done in real time though. You play the show on the cable box, and hit capture on the PC. So it takes 1 hour for a 1 hour show. For me, a 1 hour show in HD is 7-8 GB, although it does vary some, and probably depends on whether it's 720p or 1080i.
Chris
post #3448 of 5938
i'm "attempting" to capture from a comcast HD PVR, and i'm getting mixed results. the shows i'm trying to capture are recorded performances by Beck on SNL and david letterman a couple months ago.
i did a test with CAPDVHS and reviewed it with VLC on a (regular broadcast, not recorded) SD channel of something random (i think it was "peoples court" or something like that).
video and audio were fine.
so, i queued up my DVR recordings. pressed play on the TV... then went over to the PC input and hit record on CAPDVHS. went back to the TV input to watch the performance. went back to the computer and stopped the recording. saw a large file was made. great! nope
when i played this in VLC it NEVER showed any audio, and it was kind of laggy at points.
so, i repeated the capture process on the same show again. this time i saw a grey sceen was recorded for the first few minutes, then the laggy video came in.. still no audio.
third time - all i got was a grey screen, no audio
fourth time - the grey screen would come and go, when i do see video it's laggy still. no audio again.
could the problem be my PC specs can't do HD playback? or that i'm trying to record from the DVR instead of regular broadcast? or that its HD?
here are my PC specs:
P4 1.7 GHz
ASUS P4T-E
1GB RDRAM (4x256)
250 GB ATA 7200
GeForce4 128MB Ti4400
post #3449 of 5938
I'm NOT an expert, and I've never gotten a scenario like that to work, but these are some of the problems I'd expect with what you're doing:
-one may need a special Transport Stream (TS) player or converter to deal with the gross data spewed out on HDD. This data, I expect, is similar if not identical to the TS files on a DVD. Maybe worse, since it's HDTV.
-may need some extra HDDs to handle the data, and a spare PC to devote to TS conversion.
-may have to rerun conversions because of overrun and underrun problems.
-automatic resets and retries initiated by the slapcard on a standard HDD may ruin a run. Maybe a guy needs several of those special HDDS that don't do thermal resets, etc.
-if standard SD is OK then maybe it's easier to get a show from ********** than record it oneself.
-for HDTV to DVD a guy may have to wait for HD DVD burners.
post #3450 of 5938
what isn't clear to me is whether i'm having record/capture problems, or playback issues (of the raw .ts files created). if it's just a playback issue, then i'd be inclined to keep archiving stuff to my pc and sort out the playback later. my DVR is full and Rome and 24 just started new seasons
  Back to Forum: HDTV Recorders
