AVS › AVS Forum › Audio › Speakers › Radio Shack SPL
Radio Shack SPL
post #1 of 15
How much better is the analog version than the digital? Out of the 18 Radio Shacks in my area only one has the analog model and its a ways away. Would I bet OK using the digital one to calibrate my speakers or should I make the drive for the analog?
post #2 of 15
At the risk of angering the audio gods (who shouldn't be using a cheapie SPL meter anyway), I have owned both, used both, and couldn't tell the difference.
Yes, a slightly wavering needle is a bit easier to read than a fluctuating digital readout, but it is really no big deal.
BTW, the one I kept is the digital one.
Cheers,
Bill
post #3 of 15
There is no difference. Just the analog is more intuitive to see, and cheaper. The digital works 100% fine.
post #4 of 15
I more interested in knowing if you really called 18 different Radio Shacks and then considered driving a implied long distance for a discontinued SPL meter?
People are going to start thinking they are rare collectors items. Ebay?
post #5 of 15
I just got my analogue meter from Radioshack online. They have them in stock and got it in just a few days. I love mine and the needle is very easy to see and read. Unless you are going to use it everyday then go with the cheaper one. Save the 10 bucks and go get a nice meal at the local drive through on the way home to eat while watching your favorite movie.
Jeff
post #6 of 15
Jeff
Know your audience Jeff... I'd guess 80% of the forum members here have dropped at least $3000 on their speakers and called it a "bargain".
Dreamaster
post #7 of 15
Anyone have the one from Parts Express? It's a little more expensive and the specs aren't much different. Are there any others in the $50 and under price range? I was thinking about getting one and figured I'd probably just get the Radio SHack one since it's the one always mentioned.
post #8 of 15
I did a quick search on RadioShack's Web site. They do show two SPL meters:
7-Range Analog Display Sound Level Meter (Item # 33-4050), which sells for $40
and
Digital-Display Sound-Level Meter
(Item # 33-2055), which sells for $50.
I thought read from another thread that RS's SPL meters started at $30. :confused: From what I've read in this thread, it makes sense to save the $10 to get the analog meter, but if you don't want to buy from the Web site (b/c of shipping, etc.) and the brick-and-mortar store only has the digital version, then one should get that.
post #9 of 15
It was discontinued. now it is a current product again.
Why it went away..we will never know...
post #10 of 15
I figured the digital would be easier to work with, so I paid the extra $10 for it. Seemed fine to me when I used it. Came with a nice carry case too.
post #11 of 15
Apart from Radio Shack, are there any other better/more accurate SPL meters out there, regardless of price? Where can I find them? Any links?
post #12 of 15
No, I called one Radio Shack and they did a lookup in their system of all the other stores in the area. One store had three of them in stock. Its probably no longer than a 30 min drive, but i'm lazy. Its also in the city, in an area that I don't know of so that means i'll have to use mapquest to get directions, which means the directions will be wrong at some point and i'll spend another 30 mins driving around in the general area trying to find the store on my own. :)
I think i'll just get the digital one then. Whats their return policy like? I mean I only really need to use it once. After that i'll just record all the settings since i dont plan on upgrading my equipment anytime in the near future. So I guess I should just use it once and return it. Sure it's not honest, but eh.. I dont care.
post #13 of 15
The beauty of the RS meter isn't that it is accurate (it is awful), but the inaccuracies are consistent across multiple units and well-documented. This allows one to adjust their readings to get a highly accurate result.
Do other meters have this knowledge-base out there? Dunno.
Bill
post #14 of 15
Bill
RS' SPL meter is really that inaccurate? :eek: :confused:
post #15 of 15
If you can afford it, you should hang on to the meter. If you ever move your speakers, even a little, you should recalibrate. I've heard some say that they check their calibration monthly.
Here is a decent overview of home theater calibration.
And here is an overview of the meter
By the way, I've used both the analog and the digital. The rap on the digital is that it's harder to read a varying digital readout. If you're using sweep tones, or other varying test tones, that may (or may not) be true. But with the noise tones from either your receiver or one of the disks (Avia, Digital Video Essentials, Sound & Vision, etc.), the needle on the analog, or the digital readout, just goes to it's reading and holds steady. In that circumstance I find the digital easier to read. Either will suffice. Get the one you prefer and can afford.
Here are the Radio Shack SPL meter corrections
  Back to Forum: Speakers
This thread is locked
