AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › Is the global initial dialup # broken?
post #1 of 15
I had a friend who has been having broadband issues since 5/8 and
guide data is about to run out tomorrow.
I suggested they connect replay using modem until they fix the
broadband issues.
Despite multiple attempts to switch from ethernet to modem,
changing the speed 9600, 14.4, 28.8, etc. they were unable to
perform the *initial* connect where you give it your area code
and prefix and it dials the 800 # to get a list of local #s.
We hear the unit dial and the server side modem pickup and
negotiate the connection, but then the replay status switches
from "dialing" to "connecting", then "disconnecting" It never
tried to download the local numbers.
I tried it on my 50xx and it does the same thing. At first I was
tricked into thinking mine was working because I had both the
ethernet and phone line plugged in. In this case, when you
switch to modem, it dials up the 800#, but when it downloads
the phone # information it uses ethernet instead of using the
dialup modem connection, making you think the initial dialup
worked, when it didn't. When I redid the sequence, with the
ethernet disconnected, the dialup failed just as described above.
Anyone seeing this problem? It would affect people switching
from ethernet to modem who've never configured modem or
people installing replay for the first time and choosing modem.
post #2 of 15
i tried switching to phone to get my guide data tonight because i moved and haven't had my dsl installed yet. i got an "unexpected error has occurred (some long string of numbers & letters)."
so it seems to be down.
post #3 of 15
you could try putting an entire known working replayTV phone number in the 'prefix' area of the dial out. It will call the phone number you chose and the extra beeps will be ignored.
cow
post #4 of 15
i'm buying the buffalo wrb-g54k kit tomorrow to solve my issues now that my dsl will be setup so i'm not going to worry about it unless someone else needs the help.
i haven't had guide data for 10 days. kinda sucks.
post #5 of 15
I don't think replay will actually use the # for net connect until you can
configure the initial list of local phone #s. It would be nice if that worked
because the local dialins are working but the 800# for the initial master
list of local dialups is failing (it seems failing during the login because the
modems negotiate enough to get past the "dialing" stage)
Also I don't recall for sure, but I thought replay limited the prefix area
to something like 5 or 6 numbers in the recent software and this
workaround was more useful for the older generation.
post #6 of 15
Don't know if this is related in any way...
Saw a "message" from replay on the setup screen the other day that said access numbers may be changing, double check that yours still exists. I update via cable modem, so I didn't look any further.
Even so, I doubt they would ditch the main number :eek:
post #7 of 15
Solution:
1)Get a working Replay local number from a buddy
2) Pick up the phone and start dialing the number and wait to hit the last digit
3)Start your replaytv dialing
4) quickly before the replay starts to dial the *possibly* dead 800 number, tap the last phone number in on your phone (now hang up)
The rest of the numbers that the replay dials will be ignored.
Or, try this:
2) Put a dialing prefix in the replaytv as the last digit in the phone number you are trying to dial
3) Pick up the phone and start dialing the number and do not type the last digit
4) Start a manual connect with your replay. As soon as you hear it dial the last number on your phone, hang up
All the extra numbers will be ignored and you should connect.
post #8 of 15
good analysis blacknoi!
However, I thought of another catch. I think the replaytv wants to hear a clear dial tone before it wil dial out.
He could try this:
>dial a known working number on a cordless phone. Hang up on the server
>have his replaytv dial out and pull the phone line out of the replay after the dialtone comes and before the replaytv starts to dial out (you can listen in on the cordless phone, if you pick up a sec after telling the replay to connect). press the 'redial' button on the cordlessphone, plug the phoneline back into the replay, and hang up the phone.
cow
post #9 of 15
I bought two 5040s on 12/17/03 (a date that will live in infamy!) for a couple of family members. I set them up on my broadband to download the latest software, and to test them out to make sure they were working. But when I set them up at each of their homes over the Christmas holiday, I couldn't get either of them to connect using the phone lines. I had the exact same problems as described above. I finally did a factory reset on both of them, and they both connected (dial-up) without any further problems. I concluded that there's something in the configuration that doesn't get cleared out when switching from ethernet to dial-up. Both units have worked fine since then.
post #10 of 15
blacknoi's suggestions, while innovative, fell to icecow's dial tone detection
dilemma.
I ended up doing a variation/simplification of icecow's suggestion.
o I picked up a handset and let Replay dial the 800#
o once it finished dialing, I disconnected the phone plug from Replay
o hung up the handset
o picked up handset
o dialed known working local #
o reconnected phone line to replay
During this time replay was doing the countdown waiting for modem tones
and it negotiated with the substituted remote modem nicely when the
phone line was reconnected.
So it seems (for this scenario) the 800# wasn't working (there's a modem
listening but it looks like PPP login failed) but when substituting a local #
it does work.
Despite some skepticism I tried the factory reset steverap suggested and
it worked. I specifically tested the global 800 dialup prior to 382-zones
and verified it dialed, connected, but disconnected without downloading
local phone #s. I immediately performed 382-zones and configured for
modem during Initial Setup and it worked without issues.
My suspicions at this point are similar to steverap's and I'm further
*guessing* the PPP login information for local dialup and 800 dialup are
different and during the initial setup, the 800 dialup uses the correct
login, but if you configure for ethernet in the initial setup, then try to
switch to modem, the 800 dialup uses the wrong PPP login information.
Once you have modem configured properly, it doesn't bother with calling
the 800# when you switch back and forth from ethernet to modem because
it uses the dialup information previously downloaded/configured so most
people wouldn't notice this problem. Only people who initially configure for
ethernet (and thus don't have any previously saved dialup info), then later
try to configure for modem will see this problem (steverap mentioned this
indirectly) The other case is when you configure for modem, then later
need to switch area code and the 800 # needs to be contacted again.
To verify some of this theory, I performed a second factory reset, this
time configuring for ethernet in the Initial Setup and then switching to
modem. Same failure as before on the global 800 dialup. Please note
in this experiment I needed to disconnect the ethernet cable *and reboot*
prior to trying modem, or another bug in replay would cause it to dialup
then hang because it still thinks the ethernet connection is active and
even though it dials the 800#, tries to send packets to ethernet interface.
Not sure if it would make any difference but these test were run on build 141.
I think the common scenarios where this 800 dialup # would most likely
be seen would be:
1) configured initially for broadband but due to broadband problems decide
to switch to modem temporarily
2) configured initially for broadband to download latest software then
switch to modem for longer term setup
3) configure initially for broadband, then sell unit on ebay to someone who
is going to use dialup instead
4) configure for modem, then later need to switch to different area code
Hope this information is useful to somebody and thanks for all your
suggestions.
post #11 of 15
Originally posted by sfhub
dial tone detection dilemma.
There's a setting in the modem setup screen to ignore dial tone detection (or something like that). At the dialing prefix screen, if you press Zones, you'll get the modem speed panel that includes dial tone detection.
post #12 of 15
I occasionally wonder if the people with new showstoppers that came with old software (the ones that don't know the right 800 phonenumber) can the trick you did to connect to the right number without opening the showstopper.
A few people have been asking about that over the last few days. They probably haven't opened their boxes yet. Maybe we can get the to try.
cow
post #13 of 15
You're right, funny thing I've seen that screen many times and changed
the speed a few times recently and never even noticed the wait for
dial tone option. Talk about tunnel vision.
It turns out for me the variation on icecow's workaround was simpler
for me to use. I think I dialed an Oklahoma # by mistake when trying
blacknoi's suggestion because I entered the last digit '9' and didn't
pick up the phone before replay could dial out. I think 9 1-800-xxx-xxxx
is an Oklahoma # :( At least it wasn't 911.
post #14 of 15
Oh man. That would be vicious cold revenge.. put 911 in the prefix box of someone's replaytv.
cow
post #15 of 15
I just worked through all of these issues, thanks to sfhub's direction.
I wasn't able to get the blacknoi manuever to work, so it required simply restoring the factory defaults. Lost the photo partition, but as soon as the network's up again, I'll be in business.
  Back to Forum: ReplayTV & Showstopper PVRs
This thread is locked
