The guys at tedco should be able to help you, if they have anything in stock. Every time I've tried to buy antennas from them, they were out.
I am about 45 miles out and I us an antennas direct xg-43 (uhf) and an antenna craft y5-7-13 (vhf for wesh) in my attic. The antennas are fed into a cm-7777 pre-amp. This setup works perfect for me because I don't have a lot of room in my attic and the two antennas allow me to position them in different areas. Before I got the vhf antenna, I tried the diy type, but is didn't work all that well in my attic. Outdoors it would probably be fine.
Also check out lowes channel master antennas (cm3016-3020) because it would be easy to return it if it didn't work (stay away from the lowes cm amps, though). I started with a cm-3016 in my attic, but the size of the vhf portion made it difficult to aim. I ended up sawing off the uhf section, which I now use at work with no amp (about 30 miles out, but mounted outside on a 30'+ mast).
