I think I finally figured out why WGFL drops out on me every once in a while (maybe 1 to 2 times a month for 30 minutes to an hour a few hours after sunset.
Last night tropo was blowing in from Georgia. I didn't turn any antennas, just rescanned to see what was coming in when WGFL on RF28 dropped out about 11 pm (later than it normally does).
Sure enough WTXL from Tally town was pinning the needles here. Every time it would drop off the peg WGFL would decode again. Then it would go back up and bye bye WGFL.
I also had zero skip to the south. Everything was from Jacksonville, Savannah, Tally and even Columbus (virtual 3).
Considering I never could find a 28 that could possibly cause me to loss WGFL. Every time I lost WGFL before I never even tried looking on ch 27 rf, but instead would turn east and south to see if there was any tropo, of which I never found any, ever.
Another factor from my house WTXL is 2 degrees different than WGFL, so any comments I made about a longer boom yagi would not help at least for WGFL 28.
Of course with out a spectrum analyzer I am guessing as to what I saw, but the complied evidence I feel really sure WGFL is clobbered when tropo comes in from Tallahassee.
That could be bad if Bithlo even raises my noise on ch 28 by even 5 db or so, it could cause more troubles on the nights when Tally skips in.
I know from the days of playing on 2 meter SSB, that certain paths would often open for 15 to 30 minutes nightly around Florida right after sunset. My normal time for WGFL to drop is about 30 to 60 minutes after sunset (last night was odd ball and a different phenomena, meaning just strong tropo due to that low that was south of the panhandle last night).
So it's totally possible I have a weak path to Tallahassee during late Spring through early Fall, that happens right after sunset. If you look at my path to their tower, I cut right parallel to the Gulf so it could be a sea breeze event.
Mostly guessing, but I bet it is. Now next summer when I get those drop outs I can check 27.
I haven't noted any CPs for WESH's translators yet. Nor for any other xltrs or LPs in Central FL. Doesn't seem like the FCC has made much of a dent in that huge crapload of LP apps that was dumped on them when they opened the filing window.
