Originally Posted by
slb
I posted this in the 9UK owner's thread, but then realized it might be better to post it here.
I noticed that on our 50PH9UK, pressing input 2 on the remote toggles between input 2A (composite) and input 2B (svideo). Does this mean that both inputs are now usable? Our 5th generation Panny did not toggle between the the two inputs, and only one or the other could be used, with svideo having priority.
This 2A/2B feature messes up our universal remote programming. If if input 2 is requested by two consecutive macros (e.g. "Watch VCR" and then "Watch CATV"), then the plasma switches from A to B (or vice-versa). It appears that if I switch to the PC input first and then back to input 2, the previous selection is preserved.
Anyone else run into this issue?
-Steve
I just realized that I misread your question and so I have edited my reply to suggest that you do as Bruzzi suggested and check with remotecentral for discrete codes for 2A and 2B. However I am leaving my reply below on this forum in case it might help others with remote codes.
_________________________________________________________
I do not know what remote you are programming but I use the JP1 connector on RadioShack and URC remotes and the JP1 ir.exe and KeyMaster software that you can download off the Internet. For my Panasonic plasma TVs (TH-50PX60 and TH-42PX50) I build the macro so that it uses: TV;TV/Video{A/B};2 to select the Component #1 input, TV;TV/Video{A/B};3 to select the Component #2 input; and TV;TV/Video{A/B};4 to select the HDMI input. The TV/Video {A/B} opens the choices for input and the numbers 2, 3, or 4 makes the input choice.
I also have the TH-65PF9UK and I used a learning remote and ir.exe to identify the codes for the component and DVI inputs (as well as the Discrete On/Off codes) and then programmed them to the TV/Video keys on the remote. For example when the remote is in the SAT mode I program the TV/Video button to send out Setup Code 0250 EFC 187 HexCMD $3F to switch to the component input. When the remote is in the DVD mode I program the TV/Video button to send out Setup Code 0250 EFC 183 HexCMD $BF to switch to the DVI input. I then build the macros so that for example to watch using the DVD player I use DVD;TV/Video{A/B} at the begininng of the macro to switch the TV to the DVI input. All of the rest of my component sources go through my Yamaha receiver and I thus use the Yamaha to switch those sources. You can set the TH-65PF9UK to always turn on using the same input so I chose Component input so that I don't have to do a lot of switching of the TV unless I want to watch the DVD player using the HDMI to DVI cable to the DVI input of the TV.
I don't know if that helps.
