Originally Posted by iforsevilla
My 960 died last Feb 17,2012. Cause of death-- the 6-7 red blinks. I knew it was bound to happen sooner or later because on cold days when I turn it on it needed a couple of restarts to get it going. Anyways, I did lots of research and was able to find all the info I needed here, of course. It was the 2 IC chips MCZ3001DB that needs replacing. Cheapest for US vendors that time was $14-$15 a chip with a socket--ebay. I decided to get the one coming from China for $15 +$2.50 SH for 5 chips--ebay. Then I bought 2 sockets from RS for 59 cents each. Ordered it 2/19 and got it 3/7. Desoldered the 2 chips out of the board and soldered the sockets in. Pressed in the new IC chips and BINGO! My 34XBR has been resurrected!
Repair cost $35.--5 chips, 2 sockets, desoldering rod, magnifying glass.
Meanwhile, as I was waiting for the chips, I decided to try out a plasma tv from costco the Panasonic TC-P60S30 floor model for 900 + tax with 2 year warranty/90 day return. Man! plasmas sure have changed some from the last time I tried it 8 years ago. Picture looks good. Test drove it with some action dvds and blue rays, OTA signal and it sure performed well. Only gripe is that it has 920 hours of display time in costco warehouse-3 months in display. And a couple of seems to me a dot scratch on the screen. I did not want 3D so I got this lower model vs the TC-P60ST30 3D for $1200 + tax which I was thinking of getting first. Anyways, this is just as good I think for less. And the picture is really good.
The size of this 60" plasma sure makes my 960 look tiny now
. Although certain things like the tv speaker is better on the 960. Tweeking the remote and the tv options the 960 has a couple of better options as well. But size sure matters in this case. And the pictures good enough for me to keep. Now I am trap in the middle. But my 960 has no other place to go but the spot where it is in right now--living room. And thats where I was hoping to put the plasma as a replacement if I wasn't able to fix the 960. Had no plans on buying a tv and I was just trying it out but now it seems that I might keep this plasma. Its gonna be my first one if only I can figure out where else to put the XBR....
Repair cost $35.--5 chips, 2 sockets, desoldering rod, magnifying glass.Meanwhile, as I was waiting for the chips, I decided to try out a plasma tv from costco the Panasonic TC-P60S30 floor model for 900 + tax with 2 year warranty/90 day return. Man! plasmas sure have changed some from the last time I tried it 8 years ago. Picture looks good. Test drove it with some action dvds and blue rays, OTA signal and it sure performed well. Only gripe is that it has 920 hours of display time in costco warehouse-3 months in display. And a couple of seems to me a dot scratch on the screen. I did not want 3D so I got this lower model vs the TC-P60ST30 3D for $1200 + tax which I was thinking of getting first. Anyways, this is just as good I think for less. And the picture is really good.
All I know is if my 960 is ever in need of repair, I'm flying you in from San Francisco to New York no matter what the cost!
Can imagine your joy at discovering the 960 was back up and running. Good luck with the new Plasma too - and unless you are into 3D, I think you did well to avoid paying more for the 3D feature for no matter what the industry tries to spin, the picture quality is not really better due to the "advanced" technology required for 3D (3D is a dud but remember when the first signs of it being a flop became apparent, the advertising hype was changed to emphasize getting it for the best 2D picture instead?).
BTW - if both sets are in the space you wanted the Plasma, there's always those TV stands on wheels and then you can always move the Plasma in front of the 960 whenever you want to.
we tend to keep the room lowerly lit to begin with so our service and user settings were made under those conditions.
). The picture quality in component is more precise and has less digital to digital loss.
