ATTENTION ALL HDTV ENTHUSISTS WHO WANT TO RECORD, PLAYBACK AND ARCHIVE PROGRAMMING: INTRODUCING THE NEXTCOM R5000-HD.
Available now. To order use our on-line form. Buy now (before Jan. 1, 2008) and take advantage of our year-end specials.
NOW AVAILABLE FOR MOTOROLA DIGITAL CABLE and STARCHOICE!
Dish Network MPEG-4 Receiver and DVR added (Models ViP211 and 622)
Supports SageTV and Windows Media Center
Welcome to a new era in HDTV recording. Introducing the Nextcom R5000-HD, the first glitch free, all digital HDTV recording system for Dish Network, DirecTV, Bell ExpressVu, StarChoice, 4DTV(C-Band), Motorola Digital Cable and ATSC Digital Television (DTV). The R5000-HD delivers lossless digital quality capture with industry standard transport streams compatible with a wide range of playback options.
Product Description
The R5000-HD is a Window XP / 2000 based HDTV recording system installed in your set top box (STB) and connected to your PC via USB 2.0. Recorded programs are archived directly to the PC hard drive or D-VHS Tape. The R5000-HD is compatible with Dish Network, DirecTV, Bell ExpressVu, C-Band, StarChoice, Motorola Digital Cable and DTV. Simple to use PVR allows scheduling of recordings using TitanTV and Zap2it on-line interactive guides. The recorder can also be controlled with the STB's VCR timers. Playback is accomplished with either PC hardware MyHD, Roku, etc. or software VLC, Elcard, Divco, etc. (Not included). Professional installation in your existing STB is included with purchase.
The R5000-HD proudly integrates Decisionmark's TitanTV EPG (Electronic Program Guide) directly into the program. Decisionmark is the leading online EPG technology provider, making it easy to find and schedule your favorite shows for recording with a single click. TitanTV users can also schedule recordings remotely wherever Interent access is available.
Set Top Box Compatibility
Dish Network
DirecTV
Bell ExpressVu
C-Band (4DTV)
StarChoice
Technical Details
Writes standard, ISO 13818-1 MPEG-2 transport streams. Tested to be fully compatible with MPEG2 decoders such as MyHD, Roku, JVC 30000, JVC 40000, etc. Configurable output bit rate allows transport streams to be NULL stripped, standard or high. No difference in compatibility (read playability) of transport streams recorded on any supported STB. Integrated IR sender/receiver allows PC to control STB and respond to STB VCR record commands (where available).
Pricing and Availability
PC Requirements
Additional Information
The user manual for the R5000-HD is currently availbale online at http://www.nextcomwireless.com/R5000...dvr_manual.htm
For more information and to order, go to: www.r5000-hd.com
R5000-HD OFFICIAL PRODUCT RELEASE UPDATE
October, 18, 2004: The R5000-HD is officially available and on sale through our website: www.r5000-hd.com
Product Description
Dish Network
- Dish 6000
- Dish 411/ViP 211 (411 now discontinued - use 211)
- ViP 622, 722 (DVR)
(Records all HD channels from Dish Network, DTV, including and SD. MPEG-2 and MPEG-4 (H.264) fully supported. Extraction is not possible from the 622/722 DVRs)
DirecTV
- RCA DTC-100
- ProScan PSH-D105
- Hughes HIRD-E86
- Toshiba DST-3000
- Mitsubishi SR-HD5
- Philips DSHD800
(Records all HD and SD channels from DirecTV and DTV. Newer MPEG-4 models, e.g. H20, are NOT supported).
Bell ExpressVu
- Bell 6000
[*}Bell 9242
(Records all HD channels from ExpressVu including all PPV. Also records SDTV MPEG2 ExpressVU channels. Extrqaction is not possible from the 9242 DVR).
C-Band (4DTV)
- Modification of the HDD-200 outboard decoder (used w/905, 920, 922 & certain StarChoice receivers).
- Direct modification of the 4DTV receiver (905, 920, 922, etc).
(Records all HD & SD digital channels).
StarChoice
- DSR series. Any 5C-enabled boxes (Firewire port for recording) not accepted.
(Records all HD and SD channels).
- DTC2000 series and certain ealry HD boxes that are not 5C-enabled (units with Firewire port for recording are not accepted). Records all HD & SD digital channels.
Technical Details
- For latest pricing and ordering details please see website: http://www.r5000-hd.com.
- Factory warranty 12 months parts & labor.
PC Requirements
- Windows XP/2000
- One USB 2.0 port or one PCI slot and a PCI USB 2.0 adapter
- 512MB RAM
- Pentium III 1.0 GHz (Dish Network), Pentium 4 1.8 GHz (DirecTV)
- 9GB / hr Free disk space
- HDTV playback software or hardware
- Optional IEEE1394 Firewire card for recording direct to tape.
- Does not include required STB or PC.
- Built-in Media Player with satellite preview capability.
- Now includes multi-STB (tuner) support for simultaneous capture from up to 4 STBs
- Recording directly to D-VHS Tape
- Supports SageTV and Windows Media Center
Sorry to rub it in.
