AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › SA 8000hd NO PASS THRU
post #1 of 2
I have the SA8000 HD for a few weeks and I have been told DVI will not be active untill Sept. but with my SA 3250HD when I didn't use the DVI and I used the component connection I had a choice of Pass Thru or Fixed and 2 Up converts, with the SA 8000HD there is no choice I have to change it manually with each station in the settings menu to 1080i or 720p or 480p something does not seem right I should not have to switch manually with a box that was made 1 or 2 years after the Sa3250HD. What am I doing wrong.
post #2 of 2
You're doing nothing wrong. The SA8000HD does not have pass-through. Indeed, there are no dual-tuner HD DVRs available anywhere with pass-through.
Pass-through capability may or may not be added with DVI support in the SR1.2/SR1.3 release coming ~September.
This thread is locked
