I have had a Motorola 6412 for a few days now. The dual tuner capability is not functioning yet. They say it will be activated within a few weeks (yeah, and pigs fly). DVI is functioning... well sort of. The same issues with previous boxes still apply. Have to sequence the power on's, or in my case just unplug and re plug the DVI cable. I have went back to component until this is fixed. There does not seem to be any difference in PQ. I did an experiment with looking at the difference tonite. I recorded some content on DiscoveryHD on the DVR then went back and watched it thru component then DVI. I could not see any difference.
The on screen menu is the pioneer passport interface. The DVR does both analog and digital and HD content. We have been happy with it. Those who have had Tivo have liked tivo's intuitiveness better- I hear. The firmware version is 8.03 for those of you keeping score.
The unit does seem to take awhile longer to lock in to the digital channels than my old 5100 with a few hiccups and drops during the first few seconds of a new channel.
On the good side when one views the guide, you can still see the programing in the upper right hand corner.
I have no idea whether the firewire is "firing" since I dont have any firewire devices to check out with, but they said it was.
! I've been looking forward to this since I saw it in the new products section of the website early this year. Everything is fairly good for the most part, so far. The remote is much more directional sensitive than the one for the non-dvr HD box, which sucks. I usually end up doing multiple button presses before I get what I want. I also had an issue with the purchase/parental PIN, which was eventually resolved. For anyone else who can't get that enabled, the initial/default PIN is 0000. I haven't tried the DVI since I don't have the cable yet.
