Originally posted by Frank D
Re: HMDH5U
The description on the JVC website does not say anything about DTS for this model it only indicates Dolby Digital. Does that mean that this unit can not output DTS?
Regards
Frank
The stereo advantage website sure mentions it in the description:
Built-in MPEG2 Decoder for Direct Connection to HDTV via Y/Pb/Pr or HDMI (High Definition Multimedia Interface)
Digital Set-top box ready with Digital-to-Digital connection via i.Link (IEEE 1394) terminal
MPEG-2 CODEC encoding/decoding for digital recording of NTSC sources
HDTV Digital Broadcast Bitstream Recording/ Playback
D-Theater compliant with the advanced D-VHS security system
Can Record Any Type of Broadcast including HD, SD or Analog
HS mode (28.2 Mbps) for up to 3.5 hours* HDTV recording STD Mode (14.1 Mbps) for up to 7 hours* SD recording LS3 Mode (4.7 Mbps) for up to 21 hours* long-time recording * and LS5 mode for up to 35 hours* long-time recording *per DF-420 cassette
Frame Synchronizer for pristine analog-to-digital dubs
D-VHS (HS, STD, LS3) S-VHS (SP, EP) S-VHS ET (SP, EP) HiFi VHS (SP, EP) VHS (SP, EP)
Full Spec HDTV Compatible (with all 18 ATSC broadcasting formats)
DigiPure Technology for high resolution analog recording and playback
5.1 Dolby Digital Output (optical)
2 channel Linear PCM Audio Output capability
1080i, 720P, 480P and 480i
2 Sets of AV inputs
S-Video inputs
2 Sets of AV outputs
2 S-Video Outputs
1 Component Video Output (Y, Pb, Pr)
1 x Optical Digital Output
2 x I.Link Terminal (IEEE 1394), DV input only for camcorders
Front Inputs ( AV, S-Video, i.Link)
Video Navigation- Tape Number, Record date and Category sorting
MTS Decoder for SAP programs
VCR Plus+ with provided cable box controller
Express Programming
Plug and Play for automatic tuner and clock set-up
1-year / 24-event programmable timer
Av Compu Link
Multi-Brand TV/Cable/DBS compatible Glow Key Remote Control
1 Year Parts, 90 Days Labor
Weight: 13.5 lbs.(6.1kg)
Width: 17.1?(435mm)
Height: 3.8?(97mm)
Depth: 13.7?(348mm)
Availability: Usually ships the next business day.
JVC-HMDH5UManufacturer's List Price: $799.95Sale Price: $599.90
