Aargh. I just tried to set mine up today and had the HDMI problem with my HLP5663W. Did a search to see if it was solved, and I see that the problem is weeks old and apparently not resolved.
Anyone find a fix? The whole reason I spent all the $$$ on this remote was to get a super-easy setup for the family to use, and if it won't switch to HDMI, then it's essentially useless as the "family" remote.
(Ah, I just read closer. I don't have anything connected to the DVI input, so it's not switching to HDMI properly. Drat. Hopefully someone will find the discreet code soon.)
Also, the "Live TV" button isn't working on my HD Tivo, but I figure I can manually fix that one.
