SA8000HD audio out
post #1 of 4
Just got a SA 8000HD from Time Warner but the both audio digital (opt & cox) out are not supported per TW, is there anyway to make either of these work? I tried the opt, the light was coming thru the cable but it didn't work. Any ideas or am I going to have to wait till Sept.?
post #2 of 4
The digital audio output should work fine. Are you sure you've got your Dolby Digital decoder setup correctly, and selected the appropriate option for digital output through the SA8000HD menu setup (press menu twice)?
post #3 of 4
Thanks bfdtv, I'll try that out tomorrow.
post #4 of 4
Bfdtv thanks, it worked. I also was using a bad cable which didn't help.
This thread is locked
