Another legendary Channel Master product no longer made. Too bad Antennacraft or Winegard won't make a parabolic antenna anymore either. But it would indeed be cheaper to order 2 separate DB4e's and join them together with a good low loss splitter in reverse. Use the same length of coax cable connecting both. Then aim in each direction, and possibly add a good low noise preamp. But joining antennas pointing different directions can be tricky, as they can interfere. Also, 3Star has a similar antenna to the DB8e for only $69. I believe it is called 4228 also, but it is different from Channel Master, as you can point each side in different directions.Originally Posted by Vegas_Vic
Perhaps you didn't understand, I need reception from 2 directions. However, this is really just 2 DB4e antennas joined together. You can buy 2 of them for under $60 each online, and it will have the same gain as the DB8e - for $80 less.
Now, if you want to talk serious UHF gain, I give you the ChannelMaster CM4251: http://www.rocketroberts.com/cm4251/cm4251.htm
Instructions for stacking four of these beasties:
