This does not sound correct. The rail voltages are not likely that high on a typical home amplifier. You can look at the equations given on the page below, which compares power and current for A/B amps. Based on Ohm's law, a 90V rail is going to be over 1000W at 8 ohms theoretical, and I recall that a 100V rail does give over 1000W at 8 ohms.
http://www.bcae1.com/hcvsnohc.htm
Peak power is correct, but not 'rms' ratings...90v rails seems to be the sweet
spot for circuit designers for high powered home amplifiers for 500w @ 8 ohm
(rms) amplifiers give or take. ((90v x 0.7)^2 divide by 8 ohms = ~500w
Most typical home amps do not have 2 Ohm ratings, and if they do they would require very massive heatsinking without fans.
I was giving home audio amplifiers the benefit of the doubt and referring to
the high end models for comparison. The typical home audio amplifier is
not rated for 2 ohms/ch.
notice the older xls in the rack.
