AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Tampa, FL - HDTV
Tampa, FL - HDTV - Page 58
post #1711 of 1713
Originally Posted by bubbaprog View Post
I wish they'd all end their stupid weather subchannels and restore full bandwidth to the stuff they're actually supposed to be broadcasting.
Guess what? They're supposed to be broadcasting in order to make money. How they do it is up to them. If that means that adding sub-channels is the tool they've found to make money, that's what they're going to do.
If that means disappointing a relative handful of purists, and you happen to be one of them, tough luck. Get a Blu Ray player.
post #1712 of 1713
I don't, to be honest. Besides, WTSP is the only station in the area right now offering a digital weather subchannel (which is a quick way to get weather info on TV outside normal news if one doesn't have cable), and put aside, it already has enough lackluster bandwidth to it so that WTSP HD can have less compression for main CBS programming.
post #1713 of 1713
I live in Wesley Chapel in Central southern Pasco and can receive Orlando quite well until mid-morning; all channels there come in at night; I use an outdoor antenna aimed toward Orlando and can receive our locals as well, usually can decode 65 channels altogether between here and Orlando/Daytona.
