Originally Posted by mrweirdo
Sounds like maybe a splitter going bad to me. I think the HD locals are pretty high up in the frequency range(near 700mhz) so its possible you were loosing the top end.
Anyways hopefully you used a good quality replacement to avoid any future problems. The Stuff Comcast usually gives out like SVI (Signal Vision International) beats the hell out of the gold plated chinese crap most retail stores sell these days. Not sure I would go amped though unless you have a ton of televisions/devices in the house(5+)? if not you might need a tech out to adjust the signal levels at the street or the drop coming in from the street to entry point itself could have issues.
I think they did some work on the street and my signal must have been affected. I just didn't know it until I tried to tune in KOVR.
I installed a Channel Master 3414 (4way ampl splitter). I have 3 Tv tuners, 1 htpc tuner, 1 STD cable box, 1 cable modem, and I am planning on adding a few more.
