Didn't see any answer in faq to this.
I recently got a second Showstopper (80 hours - Unit #2). I plugged it into the same system (inputs, power, outputs, IR cable blaster) as my current Showstopper (120 hours - Unit #1) and the IR blaster does not work on my General Instruments Cable Box. Went through set up as normal and set the Cable Box code the same as Unit #1.... no joy. Unplugged it all and put unit 1 back on line - worked fine.
Took unit #2 and plugged it into straight cable, using the box as the tuner and it works fine on the set upstairs. I can live with this set up... but is there a way to work around the IR Blaster problem if I end up getting another cable box for the upstairs set?
Thanks for any help.
